Rocklandbiker
OUT IN THE WOODS
- 31. Oktober 2003
- 39
Kennt jemand diesen Reifen ? Erfahrungen ? In irgendeinem Test ?
Soll bei 2,25 breite ca. 590 gr. wiegen, nicht schlecht gegenüber den "Breitreifen von MAXXIS" die in der Größe schon mal gerne 7xx wiegen !
As the newest addtion to the IRC tooldbox, the Mibro has already been used to mine for gold on U.S. and European soil. Ramped center knobs and the rounded crown provide a predictable, fast rolling tread for a variety of conditions.
The all new Mibro is a culmination of IRC's 78 year long history of bicycle tire production. Developed primarily for the XC rider and racer, the Mibro will also find favor with those who desire a tire with a wider profile and more air volume, but still require a fast rolling tire. Three, basic elements were considered design imperatives when development of the Mibro commenced:
Lightweight Construction_
A supple and extremely light 127 threads-per-inch bias forms the basis for the casing build-up. Combined with IRC's super light rubber compound, the standard tire weighs in at only 470 grams in the 1.95" width.
High Rolling Efficiency_
Ramped knobs provide an easy means for the tire to crawl out of its traction divots, but the tread pattern becomes even more efficient through the thoughtful design of the knob array. The modified chevron allows the tire to stay up on the knob tracks while riding hardpack, reducing rolling resistance and the up-down-up-down sensation.
Predictable and Consistant Traction_
IRC's Hybrid Tread Compound enables the outer and inner tracks to each receive a separate rubber compound. The resulting outer knobs are stiffer to resist distortion when cornering while the tacky, softer center track provides excellent grip. Split knobs on both tracks provide twice as many working edges.
