- 15. September 2014
- 0
[QUOTE = "French bombers post: 12701382, member: 320640"] Yes, I mean the gas spring of shifters [/ QUOTE]
Looks like the same problem as mine. The shifter stays in DH position and doesn't switch to XC?
Check here:
http://www.mtb-news.de/forum/t/stri...en-und-antworten.727852/page-61#post-12699356
For everyone else a little advice: When you are switching the shifter from DH to XC mode, double check that the shifter is fully extended to XC position! If not, excessive forces occur on the shifter as the linkage is trying to compress the shifter piston. This inevitably leads to shifter failure due to large forces on the oil valve. At least I pressume that this was the problem.
jaa... genau das gleiche problem... aber ich habe die gasfeder nicht rausgezogen bekommen könnte es aber nochmal probieren wahrscheinlich wirds dann aber genau das gleiche problem wieder sein
was hat canyon bei dir dazu gesagt ?
