bin am überlegen mir ein bike zum freeriden und downhill zu kaufen...
bin jetzt am überlegen welches von diesen beiden bikes...
vielleicht könnte ihr mir ein wenig helfen...
2008 Kona Stinky Deluxe
Frame
tubing Kona Clump DH 7005 Aluminum/7" Travel
Rear Shock
Marzocchi Roco TST R
Fork
Marzocchi 66 RC3 180mm w/20mm Thru-Axle
Headset
FSA Pig Crankarms RaceFace Evolve DH X-TYPE Chainrings Rockguard /36/24 B/B
RaceFace
Evolve DH X-TYPE
Pedals
Kona Wah-Wah
Chain
Shimano HG73
Freewheel
Shimano LX (11-32, 9spd) F/D Shimano LX R/D Shimano XT Shadow
Shifters
Shimano LX Handlebar RaceFace Evolve DH OS
Stem
RaceFace Evolve DH OS Grips Kona LOG
Brakes
Shimano XT Hydraulic Disc
Brake Levers
Front hub
Sun Ringle Demon 20mm
Rear hub
Sun Ringle Demon
Spokes
DT Stainless 14g Tires Maxxis Minion 26 x 2.5
Rims
Sun MTX-Sleeved
Saddle
WTB Pure V Race FR
Seatpost
RaceFace Evolve DH Seat clamp Kona QR Colors Light Green & White Matt
Specialized BigHit FSR II 2009
RAHMEN
BigHit FSR, M4 Premium Aluminum ORE TT/DT, full cartridge bearing pivots, ISCG mount, asymetrical rear triangle, 7.5" travel
FEDERBEIN Fox Van R coil piggy back, 8.5x2.5", rebound adj., S:400, M:450, L:500
GABEL
RockShox Domain 302, 180mm travel, coil spring, external rebound adj., 20mm thru-axle w/ Maxle 360, 1-1/8" to 1.5" tapered alloy steerer tube
STEUERSATZ
1-1/8" to 1.5" Threadless, alloy, cartridge bearing
VORBAU
Specialized Aggro stem, 35mm extension, OS 31.8, 4-bolt, forged
LENKER
Specialized Big Hit rise bar, 31.8mm, 6 degree up, 9 degree backsweep, 680mm wide
LENKERGRIFFE
Specialized thin lock on grip, alloy bar ends
VORDERRADBREMSE
Avid Juicy 4R, full hydraulic, toolless reach adjust, metallic pads, 203mm rotor
HINTERRADBREMSE
Avid Juicy 4R, full hydraulic, reach adjust, metallic pads, 203mm rotor
BREMSHE
BEL Avid Juicy 4R Hydraulic
SCHALTWERK
SRAM X-9, 9-speed, short cage
SCHALTHEBEL
SRAM X-5, trigger, 9-speed
KASSETTE
Shimano HG 50, 9-speed, 11-34t
KETTE
SRAM PC -971, 9-speed w/Power Link
KURBELSATZ
Truvativ Hussefelt, 170mm w/ SBC chain guide
KETTENBLÄTTER
34t, 4-bolt, compact 104mm pattern
INNENLAGER
Truvativ Howitzer XR, oversize sealed outboard cartridge bearing, 73mm shell
PEDALE
Specialized Lo-Pro alloy
FELGEN
Specialized P-Disc, 32mm, 36h
VORDERRADNABE
Specialized Hi-Lo disc, 20mm thru-axle, 36h
HINTERRADNABE
Specialized disc, 135mm, machined flange, sealed cartridge bearing, bolt on, 36h
SPEICHEN
2.0mm stainless, black, brass nipples
VORDERREIFEN
Specialized Clutch SX 26x2.3", 60 TPI , aramid bead, cap ply, soft dual compound
HINTERREIFEN
SCHLÄUCHE
Specialized 26x2.3", schrader
SATTEL
Specialized Enduro, 8mm hollow Cr-Mo rails, SL foam
SATTELSTÜTZE
6061 butted alloy, two-bolt, 0 offset, 30.9x300mm
SATTELSTÜTZKLEMME
7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID , black
Frame
Rear Shock
Fork
Headset
RaceFace
Evolve DH X-TYPE
Pedals
Kona Wah-Wah
Chain
Shimano HG73
Freewheel
Shifters
Stem
Brakes
Brake Levers
Front hub
Rear hub
Sun Ringle Demon
Spokes
Rims
Sun MTX-Sleeved
Saddle
WTB Pure V Race FR
Seatpost
RAHMEN
GABEL
STEUERSATZ
VORBAU
LENKER
LENKERGRIFFE
VORDERRADBREMSE
HINTERRADBREMSE
BREMSHE
SCHALTWERK
SCHALTHEBEL
KASSETTE
KETTE
KURBELSATZ
KETTENBLÄTTER
INNENLAGER
PEDALE
FELGEN
VORDERRADNABE
HINTERRADNABE
SPEICHEN
VORDERREIFEN
HINTERREIFEN
SCHLÄUCHE
SATTEL
SATTELSTÜTZE
SATTELSTÜTZKLEMME
