- 18. April 2010
- 0
M55 Bike bringt mit dem Terminus ein nicht gerade günstiges E-Bike auf den Markt http://www.m55-bike.com/en
Es soll 3 verschiedene Versionen geben
einmal mit einer White Brothers Federgabel um 25.555â¬
dann mit einer hauseigenen Einarmfedergabel um 28.888â¬
und dann noch eine Air-brush Edition um 26.666â¬
alle Preise exkl. Mwst aber mit Versandkosten in der EU
As we believe the number 55 is a magical one, every 55th piece will be a special edition with custom paintjob. 5 limited series of 55 bikes will be produced. The first series will be equiped with White Brothers double crown fork, the second one with our custom 'Biceps' single-arm suspension design. A third series is âtailor-madeâ edition, excluisively produced one of a kind models on our customerâs special request. (the biceps and 'tailor made' version comes with a different price - to be anounced later)
Every purchased piece comes with a golden plate dedicated to its owner.
FEATURES
Frame:
Material: 7075 Aluminum
Construction: Self supported frame structure, integrated electric motor assist, integrated battery cell and hidden electric wiring. Single pivot suspension system, single piece cast swing arm 1:3 ratio.
Suspension travel: front: 160 mm, back: 172 mm, for use with only disc brakes
Frame size: 17", 18", 19â
Color option: Custom design and color scheme for the batch of every 55 pieces
Battery cells:
8 pcs A123 Polimer Li-Ion cells (26,4 V/20 AH)- depending on the motor size
Motor:
250-1500 Watt (on demand) BLDC electronic motor unit, more than 90% efficiency, drive-integrated rotation sensor, adjustable electronic assist. The rated speed is 540 RPM, rated torque is 30 Nm. A speed reduction gear mechanism is integrated in the motor unit to increase the maximum assist torque to 54-90 Nm (depending on the motor size)! Potential maximum speed: 40-67 km/h (depending on the gear ratio and the rider's weight)
Components:
Fork: White Brothers Groove 160 "Upside-down" fork with custom M55 crowns
Rear shock: Fox MXR Air Shocks 10.25â (260mm) / 2.80â (71mm)
Headset: Syncros FBI 1 1/8â semi-integrated
Crankset: Custom made M55 aluminum cranks, 170 mm length, ISIS Drive compatible
Bottom bracket: Custom made, CNC machined, heat treated steel spindle, ISIS Drive compatible
Front chainwheel: Custom made M55 titanium cranks
Chain: KMC X1, specifically developed for Rohloff internal gear hub
Rear cog: Rohloff, 15T, 16T or 17T
Gear change machanism: Rohloff Speedhub 500/14 tandem version
Gear shifter: Rohloff twist shifter
Brakes: Brembo front and rear, 203 mm floating discs, 2 piston design
Brake Hose: GoodridgeRace
Brake levers: Brembo brake lever body, custom M55 brake lever design
Rims: Syncros FR DS 32, 26â
Front hub: DT Swiss 20mm Thru Axle
Rear hub: Rohloff Speedhub 500/14 Tandem version
Spokes: DT Alpine II, 2,34-2 mm
Integrated handlebar and stem: Cast and CNC-machined custom model, 97 mm effective stem length, 741 mm handlebar width, integrated
Grips: Extreme Steering International 100% silicone grips
Seatpost: Syncros Carbon Seat post, 31.6, 350mm
Saddle: Selle Italia
Pedals: Syncros Meathook
Geometry:
Head tube angle: 65 degree
Seat tube angle: 73 degree
Wheelbase: 1150 mm
Chainstay length: 420 mm
Top tube length: 567 mm
Horizontaltop tube length: 600 mm
Seat tube length: 470 mm
Stepover height: 815 mm
Bottom bracket height: 370 mm
Weight: 30-32 kg (depending on the motor the model is equiped with)
FEATURES
Frame:
Battery cells:
Motor:
Components:
Geometry:
Wheelbase: 1150 mm
