Cane Creek VALT - Progressive Stahlfeder vorgestellt (05.12.2019)
22. Juli 2014
4.955
Alle Erfahrungen dann hier rein bitte. Finde ich toll, dass sich in die Richtung was tut.
https://www.canecreek.com/product/coil-shock-springs-linear-progressive/
von der CC Seite:
LINEAR AND PROGRESSIVE COIL SPRINGS.
The performance of your shock is directly related to the quality of your spring. VALT springs offer a significant weight reduction over standard steel springs. Riders can enjoy the performance benefits of coil shocks without the weight penalty.
Progressive-Rate VALT coil springs are now available from Cane Creek Cycling Components. Designed and tuned by Cane Creek’s engineering team to provide riders with a true rise-in-rate spring curve. The Progressive-Rate VALT springs maintain the sensitivity and “set it and forget it” mentality of a traditional coil set up, but with the progressiveness and ramp up that hard-charging riders and many frame designs demand. Progression begins at 50% into the stroke of the spring.
Below is a graph that shows the difference in spring progressiveness between our standard VALT spring and our Progressive-Rate VALT spring. Rate increases are proportional to an AIR CS air spring with (1) volume spacer installed
Passform: ALL Cane Creek Coil Shocks as well as: Manitou, Marzocchi, XFusion, ELKA/MRP, BOS, and DSP. Fox Racing coil shocks will also pair with the VALT springs but require a spring clip adapter. Cane Creek Part Code: .DB11253H
Yep funzionire gutt,vorallem bei Linearen Hinterbauten.Habs am Levo....500-610 Lbs bei 80kg.
Hab sie sogar noch bisschen Progresiver gemacht.
Sprindex hat mich auf die Idee gebracht,das hier ist Eigenbau aus eben Hartschaum aus alten Liftanschlägen.
