Habe selbst etwas dazu gefunden. Es sollte funktionieren.
3pos Remote Lever Installation Information
Step 1
To install a 3pos Remote lever on a GRIP or FIT4 damper or FLOAT DPS or FLOAT X shock, install the remote lever onto your handlebar. Do not exceed 15 in.-lb (1.7 Nm) torque. Less torque may be needed for carbon bars. Please see bar manufacturer's instructions for use with carbon bars. Make sure to check for clearance between the remote lever and any brake or shifter controls.
The 3pos remote lever has a built in barrel adjuster an does not require an inline barrel adjuster.
For Forks: Install a ferrule on the remote lever end of your cable housing, the fork topcap end does not require a ferrule.
For Rear Shocks: Install ferrules on both ends of the cable housing.
Step 2
For GRIP dampers: Set the remote lever to Firm mode by pushing the silver actuation lever down to it's lowest position, then go to step 6 of the
GRIP Remote Installation »
For FIT4 dampers: Set the remote lever to Open mode by pushing the black release lever, then go to step 6 of the
FIT4 Remote Installation »
For FLOAT DPS and FLOAT X rear shocks: Set the remote lever to Open mode by pushing the black release lever, then go to step 5 of the
FLOAT DPS and FLOAT X Remote Installation »
