- 11. Juni 2021
- 43
Hallo u. guten Tag,
für ein Rad in der Pariser RER & RATP - ist hier ein extra Ticket notwendig!?
hab mal gehört dass das Fahrrad in der Métro ansich eher NICHT erlaubt ist, dafür aber in den RERs. Also - das würde dann ja bedeuten, dass wenn man eine RER-Verbindung hat, um näher an dein Ziel zu kommen dann würde das gehen!?
vgl https://www.ratp.fr/en/it-possible-carry-my-bicycle-ratp-network
Is it possible to carry my bicycle on the RATP network?
Published on 09 August 2022 Print/Download
For obvious reasons of available space, you are not allowed to carry your bicycle on the metro, bus, tramway or Montmartre funicular. On metro line M1, however, bicycles may be transported on Sundays and bank holidays before 4:30 p.m. Please ask the station agent to open the service gate after validating your travel pass.
On the RER, you may transport your bicycle and make transfers only between RER lines A, B, C, D and E, and only during the following hours:
All day long on Saturdays, Sundays and bank holidays, Before 6:30 a.m., between 9 a.m. and 4:30 p.m., and after 7 p.m. on all other days. You are responsible for the transport, handling and surveillance of your bicycle. You must store your bike in one of the compartments with a special bicycle indicator (bicycle sticker) and hold on to it.
You are not allowed to use the escalators with your bicycle.
The use of roller skates, skateboards, scooters, bicycles or any other type of cycle is strictly forbidden within the network and in the trains, regardless of which transport mode you use (RER, metro, bus or tram). You will be held fully responsible for any accidents that occur to you or to third parties, as well as to RATP and its staff.
