@stuntzi: Coole Bilder - sieht echt "heiss" aus, dort drüben! Verpass dir keinen Hitzeschlag, ja?! Mir wärs lieber, du hättest ein Notfall SAT-Telefon... Obwohl dort eher kein Rettungshubschrauber dich suchen würde - aber trotzdem...
Zum Internet: Ich weiss, dass Du kein Blackberry hast. Aber die Anleitung habe ich ganz gut gefunden, insbesondere auch CDMA ist dokumentiert. Anscheinend sei der Verbindungscode #777 (siehe unten Anleitung).
Link ist sonst
hier.
Alles Gute und pass auf dich auf!
8. IMPORTANT SPECIAL CONFIGURATION STEP
Click Properties -> Advanced. Add only ONE of the following Extra initialization commands with the appropriate carrier-specific APN Setting:
* For Vista users only: Under Control Panel>Phone and Modem>Properties on the General Tab, click "Change Settings". After giving Administrator approval, click the Advanced tab. There, enter the appropriate APN settings for your carrier as noted below.
TMOBILE USA Users (Success!)
+cgdcont=1,"IP","wap.voicestream.com"
This is a newer string from TMO that works: +cgdcont=1,,"wap.voicestream.com"
Another alternate string (required for BlackBerry 8100 Pearl & BlackBerry 8800): +cgdcont=1,"IP","wap.voicestream.com"
Rogers Users (Success!)
+cgdcont=1,"IP","internet.com"
Cingular Blue/AT&T Users (Success!)
+cgdcont=1,"IP","proxy"
Cingular Orange Users (Success!)
+cgdcont=1,"IP","ISP.CINGULAR"
at&t Users (Success!)
AT+cgdcont=1,"IP","WAP.CINGULAR"
UK Vodafone Users (Success!)
+cgdcont=1,"IP","internet"
Verizon Users (Success!) - Keep blank
Nextel/Telus iDEN Users (untested) - Keep blank
Sprint/Bell Mobility CDMA Users (untested) - Keep blank
9. Add A New Internet Connection
Close the Phone and Modem Options and the Control Panel.
For XP: Create a new connection with Start -> Connect To -> Show all connections -> Create a new connection.
1. Click Next
2. Select "Connect To The Internet" then Next
3. Select "Set up my connection manually" then Next
4. Select "Connect using a dial-up modem" then Next.
For Vista: Create a new connection with Start -> Connect To ->
1. Set up a connection or network
2. Choose a connection option: Click on "Connect to the Internet (Set up a wireless, broadband, or dial-up connection to the Internet."
3. You are already connected to the Internet - Click on "Set up a new connection anyway"
4. At "How do you want to connect?" Click on "Dial-up"
5. Check only the Standard Modem (if prompted).
6. Give the connection a name such as "BlackBerry Modem", then Next.
7. On the next screen, pick one of the following phone numbers, depending on your carrier:
....If you use GSM/Cingular/AT&T/TMobile/SwissCom: Enter phone number *99#
....If you use iDEN/Nextel/Telus: Enter phone number S=2
....If you use CDMA/Verizon/Sprint/Bell Canada: Enter phone number #777
8. Click Next.
9. On the next screen, pick one of the following, depending on your carrier:
....If you use Cingular Blue, AT&T or Nextel:
.........Username: (blank)
.........Password: (blank)
....If you use Rogers Canada:
.........Username: wapuser1
.........Password: wap
....If you use Cingular Orange:
.........Username:
[email protected]
.........Password: CINGULAR1
....If you use T-Mobile:
.........Username: (Your TMobile 10-digit phone number)
.........Password: (Your existing TMobile.com Password)
.........Note: In USA, you can leave both blank
....If you use Verizon, replace 8005551212 with your phone number:
.........Username:
[email protected]
.........Password: 8005551212
....If you use Sprint:
.........Username: (Your existing Sprint PCS Username)
.........Password: (Your existing Sprint PCS Password)
....If you use Bell Mobility, replace 8005551212 with your phone number:
.........Username:
[email protected]
.........Password: (Your Bell Mobility Voicemail PIN)
10. Clear all checkboxes ("Use...when anyone..." and "Make this the default...")
11. Click Finish
10. Disable IP Header Compression (*Vista users, see the note below)
Make sure TCP/IP Properties (Advanced) "Use IP Header Compression" checkbox is NOT checked. To verify this, do these steps:
1. Start Menu->Network Connections->"BlackBerry Modem"
2. Click Properties Button
3. Click Networking Tab
4. Select "Internet Protocol (TCP/IP)"
5. Click Properties Button
6. Click Advanced... Button
7. Disable "Use IP header compression" checkbox
8. Click all OK buttons to close all dialogs
Also make sure you clear all these checkboxes, if you see any of these checked:
Turn off "Enable Hardware Flow Control"
Turn off "Enable Modem Error Control"
Turn off "Enable Modem Compression"
