- 17. Mai 2008
- 3.783
Bist nicht du Fotograf? Hinterheeeeer....Vielleicht bekommen wir zeitnah Infos aus Frankreich...Spyshots oder sowas
The (static) geometry will remain, and dynamic geometry depends on the spring you ride. The only change that will come is more travel in the rear - but you may use this to soften the rear suspension. Then SAG will increase, head angle as well as seat angle will slacken and the BB will be slightly lower. Reach will also become a little shorter.I will go for coil with jadeX
230x57.5
or 230x60?
geometry will change a lot with 230x60?or not?
thanks in advance!
will have problem with bottom outs or not?because I read people afraid of that situation and go with full cascade link patent!The (static) geometry will remain, and dynamic geometry depends on the spring you ride. The only change that will come is more travel in the rear - but you may use this to soften the rear suspension. Then SAG will increase, head angle as well as seat angle will slacken and the BB will be slightly lower. Reach will also become a little shorter.
I think the rear sus kinematic of the MT is progressive enough for coil (as it is designed to work with coil shocks in stock). So you will not need a cascade link or progressive spring, but as I run a Topaz air shock, can't tell you from experience. If you still have the wish to try one or both of them, feel free.will have problem with bottom outs or not?because I read people afraid of that situation and go with full cascade link patent!
I understand what you said and your are amazing with your post thanks a lot buddy!
maybe first will go with stock sizing and if I bought the cascade link just change the spring clip this is so cool in dvo shocks!
Im thinking to go with proggressive coil
dvo said to me in mails have to choose 525/610 for my megatower and my 90kilos full equipped!
I have medium size frame!I think the rear sus kinematic of the MT is progressive enough for coil (as it is designed to work with coil shocks in stock). So you will not need a cascade link or progressive spring, but as I run a Topaz air shock, can't tell you from experience.
But a coil shock bottom-out is not the problem as far as the rear sus is not forced to move beyond the travel. 60mm travel of a shock is possible on size LARGE without any hardware problem.
Just try/measure out, but I guess that 60mm shocks will work on medium size, too!I have medium size frame!
I see racing fast guys runs progressive coils rear in MT and works nice....
Topaz had it in my previous frame Canfield bikes Riot 3 years serious shock and very good suspension but I want coil for my mega
Wenn ich frei hätte sehr gerne...n bisschen Biken mit dem european Syndicate und Fotos machen...wär schon geil :-DBist nicht du Fotograf? Hinterheeeeer....
Würdet ihr im Hinblick auf den Release des MT V2 im Frühjahr aktuell mit dem Kauf eines (gebrauchten) Rahmens warten, oder glaubt ihr Lieferzeit und Preis wird eh so hoch sein, dass warten nicht lohnt?
Habe nen gebrauchten Megatower Rahmen mit Rockshox Super Deluxe Coil angeboten bekommen und überlege ob ich zuschlagen oder warten soll, damit sich der Preis weiter nach unten korrigiert, sobald die neue Version raus ist.
Nomad und Bronson Updates waren ja auch keine Meilensteine...das aktuelle Megatower finde ich durchaus noch aktuell. 2000 Eur gebraucht faend ich als Baseline auch akzeptabel. Neu gibt es die Rahmen momentan aber wohl auch zu bekommen.Ich kaufe bevorzugt gebraucht, dann ist der Preisverfall schon durch. Kommt jetzt auf den Gebrauchtpreis an, aber sofern der u 2000€ mit Dämpfer liegt, könnte man an deiner Stelle stark drüber nachdenken.
Ich kann nur fürs Bronson sprechen. Da wäre die neue Geometrie, vor allem der Sitzwinkel, und das 29" Vorderrad für mich schon ein Meilenstein. Das Nomad Update zum V5 war mir auch etwas fad. Schade, dass das wohl aussterben wird. Ich denke ein V6 wirds wohl kaum geben, wenn sie dieses Jahr das Megatower mit 77(Komma fünf?) Sitzwinkel ausstatten und vorne etwas flacher machen. Oder sie trauen sich mal was Neues und geben dem MT verstellbare Geometrie. Das wäre mal was.Nomad und Bronson Updates waren ja auch keine Meilensteine...das aktuelle Megatower finde ich durchaus noch aktuell. 2000 Eur gebraucht faend ich als Baseline auch akzeptabel. Neu gibt es die Rahmen momentan aber wohl auch zu bekommen.
So ganz falsch war die Mutmaßung gar nicht.Sooo, SC Marketing Deutschland, die bekannten SC Fahrer aus dem deutsch-sprachigen Raum, alle hängen sie in der Provence rum. Die werden sich dort nicht aus Spaß getroffen haben, sondern um knallharter Arbeit nachzugehen.
Ich tippe, dass wir bald das Megatower Update zu Gesicht bekommen werden.
Jau, ist auch ein schönes Rad geworden. Leider mit Neupreis weit außerhalb meiner Zahlungberwitschaft. So wird’s dann halt ein gebrauchtes Heckler V1 in ein paar Monaten, wenn dessen Preise gut gepurzelt sind. Das heckler V1 würde mir als Nummer auch schon gut gefalle.So ganz falsch war die Mutmaßung gar nicht.
Wurde nur kein Megatower vorgestellt sondern das neue Heckler.
By the way: Das Pistazie ist ne geile Farbe. Das MT hätte diese Farbe verdient gehabt.
