Rock Shox Spare Part Catalog auf dieser Seite:
http://www.sram.com/de/service
Auf Seite 21 findest du die RS-Teilenummern der 2010er Recon-Federn ohne U-Turn:
11.4015.437.010 Coil/Shaft Assy, X-Soft Silver 120mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.020 Coil/Shaft Assy, Soft Yellow 120mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.030 Coil/Shaft Assy, Med Red 120mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.040 Coil/Shaft Assy, Firm Blue 120mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.050 Coil/Shaft Assy, X-Firm Black 120mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.060 Coil/Shaft Assy, X-Soft Silver 100mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.070 Coil/Shaft Assy, Soft Yellow 100mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.080 Coil/Shaft Assy, Med Red 100mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.090 Coil/Shaft Assy, Firm Blue 100mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.100 Coil/Shaft Assy, X-Firm Black 100mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.110 Coil/Shaft Assy, X-Soft Silver 80mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.120 Coil/Shaft Assy, Soft Yellow 80mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.130 Coil/Shaft Assy, Med Red 80mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.140 Coil/Shaft Assy, Firm Blue 80mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
11.4015.437.150 Coil/Shaft Assy, X-Firm Black 80mm - 2010-2011 Tora/Recon XC Series 32mm (requires Top Cap Kit - Tora or Recon)
