Felt Q7FW vs. Stevens S6
11. April 2006
454
Franken
Wie der Titel schon sagt. Was haltet Ihr für das bessere Rad für ein Mädel das gerade aus seinem 24'er rausgewachsen ist.
Felt:
Q7 FW
Farbe:
Pitch Black
Grösse:
12.5, 14.5, 16.5, 18.5
Rahmen:
FELT WOMENS SPECIFIC FRAME 6061 Double Butted Aluminum, Fully Hydroformed Top Tube, A-Style Seatstay Design, Oversized Semi-Integrated Head Tube, Replaceable Derailleur Hanger, Rack & Fender Mounts, Basta-Lock, Disc Brake Specific
Gabel:
RockShox Dart 2 with Turnkey lockout Aluminum Lowers, Aluminum Crown, Steel Steer Tube, 28mm Upper Tubes, Preload Adjust, 100mm Travel. Disc Brake Specific Lower Legs.
Steuersatz:
Semi-Integrated 1-1/8" Aheadset--Steel Cups, Caged Bearing, with Alloy Laser Top Cap, Custom Curved 1 x 15mm + 2 x 5mm Straight Washers
Vorbau:
FELT One-Piece Melt-Forged Design, 1-1/8" Threadless Aluminum, 4-Bolt, 10 Degree Rise. CP Hardware BLAST BLACK Extensions: 12.5-16.5=90mm; 18.5=110mm
Lenker:
Butted Aluminum Riser, 35mm Rise, 25.4 Bar Bore, 8 degree Bend, 4 Degree up sweep, with Felt Laser Logos. Widths: 600mm
Griffe:
Felt Dual-Density Extra-Soft & Sticky (Recipe #25)center with Hard Outer Durometer, 130mm Length, 30mm OD, Grey outer/Blk grip section
Schalthebel:
Shimano Deore SL-M530 Rapidfire Plus 27 Speed
Umwerfer vorne:
Shimano Deore FD-M531 Bottom Pull
Schaltwerk hinten:
Shimano SLX "SHADOW" Top-Normal Version RD-M662
Kurbel:
Truvativ Iso-Flow (9-sp), Melt-Forged Aluminum, 44/32/22T Steel Rings, Lengths: 12.5-17.5=170mm; 18.5=175mm, With Chainguard
Innenlager:
Truvativ Powerspline BB, Cartridge, Cr-Mo Axle & Cups
Freilauf:
SRAM PG-950, 9-Speed Cassette, 11-32T
Kette:
Sram PC-951 (9-Speed) Silver Outer
Bremshebel:
Shimano Hydraulic BL-M486
Bremsen:
SHIMANO BR-M486 HYDRAULIC Twin Piston Caliper design Organic pads, Rotors: 180mm Front; 160mm Rear
Züge:
Custom Felt Cable Set, Standard Black Casing, Featuring CP Stamped Logos & FELT Rubber 2-Tone Tube Tops at Head Tube and One Red CNC Alloy ferrule Brake hose supplied with Brakeset
Sattel:
Felt "RXC" Womens specific Version Low Side Profile Look with Wide/Flat/Plush Top, Double-Density Base, Satin Steel Rails
Sattelstütze:
Felt Alloy Micro-Adjust, 100% Black, 6061 Low-Profile Forged Head & Extruded Rall Clamps, 27.2mm x 350mm (CEN)
Sattelstützklemme:
Felt Bolt-Type with Logo, Cold Forged + CNC, 6061 Aluminum, with Steel Barrel Nut Design, 31.8mm
Nabe vorne:
Shimano HB-RM65 w/CenterLock, 32H, with Quick Release
Nabe hinten:
Shimano FH-RM65 8/9 Speed Cassette w/CenterLock, 32H, with Quick Release
Felgen:
WTB SX 24 Disc Doublewall, with Single Eyelets, 26 x 1.5 x 32H, 24mm Width, Presta Valve, Black Anodized, 460g
Bereifung:
FELT THC XC Trail Highway City 26 x 2.1 30TPI Wire Bead, with Presta valve Inner Tubes
Speichen:
Sandblast Black Stainless DB 14/15G, Brass Nipples
Pedale:
MTB Design Alloy Cage / Alloy Body, 442g
Gewicht:
13,1 Kg
Stevens:
Chassis
Headset FSA Ahead Integrated Mod. 11, 1 1/8"
Brakes Shimano disk brake BR-M486 180/160mm
Frame tubing Aluminium 7005DB t-wall
Front fork SR Suntour Raidon LO Air, 80mm, Lockout, alu shaft
Drivetrain
Crankset Shimano FC-M442, 44-32-22, chainring guard, Octalink
Derailleur r Shimano Deore RD-M531
Derailleur f Shimano Deore FD-M531
Chain Shimano CN-HG53
Cassette Shimano CS-HG50.9 11-32
Pedals MTB Alu Dual Side
Gear ratio 1.4 – 8.4 m
Wheelset
Hubs Shimano Deore FH/HB-M65 Disc, sealed
Rims Rigida Taurus Disc 32 L
Spokes Niro stainless steel conified 2.0-1.8mm
Tires Continental Race King, 26x2.2", foldable
Cockpit
Handlebar Oxygen Driver Riser, Alu 2014, 63 cm
Stem Oxygen Driver, 25.4mm, stainless bolts
Saddle Oxygen Raceline
Seatpost Oxygen Driver 380mm
Shiftlever Shimano Deore SL-M530
Brakelever Shimano Disc BL-M486
Data
Weight 12.7 kg
Sizes 15, 18, 20, 22"
Color(s) Velvet Black | Grey Black
Gewicht spricht für das Stevens. Zur Gabel kann ich nichts sagen. Würde beide zu fast demselben Preis bekommen. Das Felt vielleicht 20-30€ günstiger. Die anderen Alternativen in den Shops in der Umgebung habe ich schon ausgeschlossen. Versender kommt für mich nicht in Frage.
wenn sie gerade erst aus ihrem 24" raus gewachsen ist, könnte die kleinste Größe bei Stevens problematisch werden. Wenn du die Gelegenheit hast, lass sie auf den Rädern sitzen und der Händler soll sich das genauer ansehen.
Ich kenne das Steven nicht, nur bei den Laufrädern und der Gabel vom FELT wirst du wohl kaum Probleme bekommen.
Ich habe Sie schon mal auf einen 40cm Hardtail gesetzt. Sind halt gerade so dazwischen. Das vorhandene 24'er ist für Touren definitiv zu klein, das kleine 26'er grenzwertig.Tendiere momentan zum Felt, da der Rahmen eben etwas kleiner erhältlich ist.
