how fit fox 36 talas to spice lapierre 516 frame?
hello again ..i will continue with my questions ....i will answer at the end of all that you write before ...next
can this fit ?
Sram XG 1199 kette fit SRAM X9 Disc 6-Loch HR-Nabe?
yes i have 1,5 straight tube...
22046760_10212155190332944_6248410605421220392_n.jpg 22154170_10212155190212941_649448227203448174_n.jpg 22050020_10212155190012936_2395098032487196716_n.jpg 22008441_10212155189612926_5951072425377634023_n.jpg 22049842_10212155189332919_4944736926299472707_n.jpg 22046760_10212155190332944_6248410605421220392_n.jpg 22154170_10212155190212941_649448227203448174_n.jpg 22050020_10212155190012936_2395098032487196716_n.jpg 22008441_10212155189612926_5951072425377634023_n.jpg 22049842_10212155189332919_4944736926299472707_n.jpg
I am person that I don’t stop to look for any different idea from normal one. The problem is I can't speak your language to explain you what i mean .. I have made many thinks working with different object as that it made from ...so that’s I ask a lot of questions I it is possible that I ask and what problem I will have if I make as I think. If you can answer what problem I will have if I cut the tube and glue if it is the correct word .it is my first time to build bicycle I don’t hurry up .so I bought until now those thinks that is in photo and many of that is in transport.
can this fit ?
Anhang anzeigen 648761 Anhang anzeigen 648762 Anhang anzeigen 648763 Anhang anzeigen 648764 Anhang anzeigen 648765 Anhang anzeigen 648761 Anhang anzeigen 648762 Anhang anzeigen 648763 Anhang anzeigen 648764 Anhang anzeigen 648765
finaly i found used....
now my next questions.i have SRAM-X9...can this fit sram xx1 kassette xg1199xd 11 fach?
Finaly i made it..little more thinks....22550022_10212318033043910_2092360539421494009_n.jpg 22550041_10212318032483896_5294090971872131255_n.jpg 22552712_10212318031923882_2871886138505159526_n.jpg 22554972_10212318033763928_4625758762570792181_n.jpg 22687557_10212318034483946_4600473327517303108_n.jpg 22688611_10212318030883856_235764035898433810_n.jpg 22728826_10212318035763978_8390631725708574286_n.jpg 22730255_10212318035323967_3023017299553257581_n.jpg
