    ➡️ Jetzt bestellen.
Linux Problem mit apt-get
9. April 2001
Freiburg
Hi Linuxer,
hab mal wieder etwas viel rumgespielt - naja und nun klappt mein apt-get nichtmehr.
Also folgendes - wenn ich z.Bsp ein apt-get install tuxracer mache kommt.
Reading Package Lists... Done
Building Dependency Tree... Done
You might want to run `apt-get -f install' to correct these:
Sorry, but the following packages have unmet dependencies:
chromium: Depends: xlibmesa3-gl but it is not going to be installed or
libgl1
libglpng: Depends: libgl1
libqt3c102-mt: Depends: xlibmesa3-gl but it is not going to be installed or
libgl1
libsdl-perl: Depends: xlibmesa3-gl but it is not going to be installed or
libgl1
libwxgtk2.2: Depends: libgl1
pia: Depends: xlibmesa3-gl but it is not going to be installed or
libgl1
qt3-dev-tools: Depends: xlibmesa3-gl but it is not going to be installed or
libgl1
tuxracer: Depends: tuxracer-data (>= 0.61-1) but it is not going to be installed
Depends: libgl1
winex: Depends: xlibmesa3 but it is not going to be installed or
libgl1
xawtv: Depends: xlibmesa3-gl but it is not going to be installed or
libgl1
xbase-clients: Depends: xlibmesa3 but it is not going to be installed or
libgl1
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Wenn ich dann das vorgeschlagenen apt-get -f install mache kommt:
Correcting dependencies... Done
The following extra packages will be installed:
xlibmesa3-gl
The following NEW packages will be installed:
xlibmesa3-gl
0 packages upgraded, 1 newly installed, 0 to remove and 154 not upgraded.
158 packages not fully installed or removed.
Need to get 0B/3763kB of archives. After unpacking 10.6MB will be used.
Do you want to continue? [Y/n] Y
Richte libgcc1 ein (3.3-0pre9) ...
Richte gcc-3.3-base ein (3.3-0pre9) ...
Richte libstdc++5 ein (3.3-0pre9) ...
Richte dselect ein (1.10.10) ...
(Lese Datenbank ... 108218 Dateien und Verzeichnisse sind derzeit installiert.)
Entpacke xlibmesa3-gl (aus .../xlibmesa3-gl_4.2.1-6_i386.deb) ...
dpkg: Fehler beim Bearbeiten von /var/cache/apt/archives/xlibmesa3-gl_4.2.1-6_i386.deb (--unpack):
versuche »/usr/X11R6/lib/libGL.so.1.2« zu überschreiben, welches auch in Paket fglrx-glc22 ist
dpkg-deb: Unterprozess paste getötet mit Signal (Datenübergabe unterbrochen (broken pipe))
Fehler traten auf beim Bearbeiten von:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Vorschläge????
Ach ja hat jemand ein howto wie man 3D Beschleuningung mit ATI Radeon karten hinbekommt???
Original geschrieben von tobi
Hi Linuxer,
Nutze dselect, das ist schöner als pures apt-get. :)
Vor allen Dingen denkt es an sowas wie Recommends und Suggests.
(Okok, das apt 0.5.5.1 in sid zeigt zumindes an was es ignoriert...)
Entweder xlibmesa3-gl oder fglrx-glc22 kriegen nun von dir einen Bugreport. Wobei... Das fglrx... kein Paket in Debian ist, lt. packages.d.o. Also schreib den Ersteller an und töte ihn halt so. :)
fglrx-glc22 deinstallieren. Oder mal händisch dpkg anwerfen. dpkg --force-overwrite /var/cache/apt/archives/xlibmesa3-gl_4.2.1-6_i386.deb und dpkg somit zum Überschreiben der Datei bringen. Danach den normalen apt-lauf für den Rest der Pakete durchführen.
Evtl. den dri-trunk von X nehmen. Such mal nach daenzer und dri-trunk bei google. Oder geh zu people.debian.org/~daenzer. Der hat sowas im Angebot.
Zumindest die Radeon in meinem ibook rennt damit.
Danke das mit dem --force-overwrite hat geklappt. Jetzt muss ich nur noch die Radeon zum laufen bekommen.
Tuxracer machst momentan 0,5 Bilder pro Sekude oder so. Und UT2003 startet noch nichtmal.
