Moin,
ich will mir das Specialized Rockhopper Pro kaufen. Ich habe allerdings die Wahl zwischen dem 2005er oder 2006er, beide zum gleichen Preis.
Da sich die Ausstattung geändert hat, könnt ihr mir vielleicht helfen welches besser ist.
Hier die Daten:
2006er:
FORK Recon 351SL Air (disc only, no brake bosses) 100mm, Motion Control
Damping, 1-1/8" Alloy Steer, 32mm alloy stanchion, lock out and rebound adjust
HEADSET 1 1/8 Threadless
STEM Alloy 7 degree rise, Four Bolt Clamp
HANDLEBARS SBC Butted XC Rise 6x8 degree, 640mm
TAPE/GRIPS SBC Enduro, dual density
FRONT BRAKE Avid SD-3R with RW cartridge pad
REAR BRAKE Avid SD-3R with RW cartridge pad
BRAKE LEVERS Avid FR-5
FRONT DERAILLEUR Shimano Deore, 34.9mm clamp, top swing, dual pull
REAR DERAILLEUR Shimano XT, SGS cage, standard spring
SHIFT LEVERS Shimano Deore, 9spd
CASSETTE FREEWHEEL SRAM PG-950 11/34t
CHAIN SRAM PC 951, 9spd w/power link
CRANKSET Shimano "Cobra" Hollow Tech Octalink
CHAINRINGS 22S/32S/44A
BOTTOM BRACKET Shimano, BB-ES30 68x113mm
PEDALS Shimano SPD 505 Clipless
RIMS Mavic XM-317, 26, 32H, with eyelets
FRONT HUB SBC Disc, Sealed Cartridge 32h, w/alloy axle and machined disc mount, hi-low flange
REAR HUB Shimano 475 Disc, 32h
SPOKES 1.8mm black stainless, brass nipples
FRONT TIRE Specialized Fast Track 26x2.0", 120 TPI, aramid bead, dual compound
REAR TIRE Specialized Fast Track 26x2.0", 120 TPI, aramid bead, dual compound
TUBES Specialized schraeder valve
SADDLE Specialized Body Geometry Sport MTB with hollow Cr-Mo rails, super-light foam
SEAT POST 2014 alloy, black, 30.9 x 350/400mm
SEAT BINDER Specialized forged alloy with QR
2005er:
FORK Manitou Black Elite LO,100mm, Fluid Flow Damping with adjustable rebound and Lock Out, alloy steerer and 30mm stanchions, coil spring with disc only magnesium lower
HEADSET 1 1/8 threadless, black steel cups, loose ball bearings with seals
STEM Alloy 7 degree rise, cold forged and TIG-welded, Four Bolt Clamp, 13/15/17: 75mm, 19/21: 90mm, 23: 105mm extension
HANDLEBARS Specialized XC Rise Bar, 6066 alloy, 6 degree upsweep, 8 degree backsweep, 640mm width
TAPE / GRIPS Specialized double density Kraton
FRONT BRAKE Avid SD-5R V brakes with cartridge pads
REAR BRAKE Avid SD-5R V brakes with cartridge pads
BRAKE LEVERS Avid FR-5 V brake levers
FRONT DERAILLEUR Shimano M510 Deore, 34.9mm clamp, bottom pull
REAR DERAILLEUR Shimano M750 XT
SHIFT LEVERS Shimano SL-M510 Deore
CASSETTE Shimano HG-50 LX, 9-speed, 11x34t
CHAIN Shimano HG-73
CRANKSET Shimano Deore, Hollowtech arms, Octalink Spline, 13/15:170, 17-23:175mm
CHAINRINGS 44alloy/32s/22s, Shimano ES spline (Octalink), alloy hardware,
BOTTOM BRACKET Shimano, BB-ES30 68x118mm
PEDALS Shimano PD-M505 clipless
RIMS Mavic XM 317, 26 x 32H, machine sidewalls with eyelets
FRONT HUB Specialized Stout Disc, 32 hole, cartridge bearings, 9mm Skraxle
REAR HUB Shimano M-475 Disc, 32 hole, loose ball bearings, alloy Q/R
SPOKES 1.8mm (15g) black stainless, brass nipples, L260/R263mm front, L261/R260mm rear
FRONT TIRE Specialized Resolution Pro 26 x 2.0, aramid bead
REAR TIRE Specialized Resolution Pro 26 x 2.0, aramid bead
TUBES Specialized, schraeder valve
SEAT BINDER Alloy collar with Q/R, 34.9mm clamp I.D., black
Danke für Eure Tipps!
Hier die Daten:
2006er:
2005er:
CHAIN Shimano HG-73
