Verkaufe Canyon Spectral CF 9.0 Größe S (bei Interesse PN)
31. Oktober 2016
17
Specifications
Product Canyon Spectral CF 9.0 SL Bike
Riding Type Enduro / All-Mountain, Trail
Rider Unisex
Sizes and Geometry S
Wheel Size 27.5" (650b)
Frame Material Carbon Fiber
Frame Material Details High strength carbon with internal cable routing
Rear Travel 140mm
Rear Shock FOX Factory Kashima Float DPS EVOL
Fork FOX Factory Kashima 34 Float
Fork Travel 150mm
Head Tube Diameter Tapered
Headset Cane Creek 40
Handlebar Canyon H23 Rise CF, 740mm, 15mm rise, backsweep 9°, upsweep 5°
Stem Canyon V12, angle +/- 6°, 1 1/8" stem clamp
Grips Ergon GE10 slim
Brakes Shimano XTR Trail with 200mm front/180mm rear rotors
Brake Levers Shimano XTR Trail with 14mm deep lever
Drivetrain 1x
Shifters Shimano XTR, SL-M9000, 11-speed
Front Derailleur Shimano XTR
Rear Derailleur Shimano XTR Shadow Plus, RD-M9000
ISCG Tabs Yes
Chainguide Canyon, integrated and mounted beneath chainstay
Cranks Race Face Next SL, direct mount
Chainrings 24/34 tooth
Bottom Bracket Race Face
Pedals None included
Chain Shimano CN-HG900-11
Cassette Shimano XTR, 11 x 40 tooth, 11-speed
Rims DT Swiss XM 1501 Spline One, 30mm width
Hubs DT Swiss XM 1501 Spline One, DT Swiss ratchet system
Spokes DT Swiss XM 1501 Spline One, forged straight pull
Tires Continental Mountain King II Protection, 2.4"
Saddle Ergon SME3 EVO
Seatpost RockShox Reverb Stealth, 125mm length
Seatpost Diameter 30.9mm
Seatpost Clamp Standard
Rear Dropout / Hub Dimensions 142mm x 12mm
Max. Tire Size
Bottle Cage Mounts Yes
Colors Stealth
Petrol carbon
Weight 26 lb 7.3 oz (12,000 g)
Miscellaneous Internal cable routing
Included in delivery: torque wrench, shock pump and frame protection
+ zusätzlich verbauter Fox Shifter für die Gabelfederung
Nicht im Lieferumfang: Pedalen und Flasche/Flaschenhalter
VB 3.000€
