    ➡️ Jetzt bestellen.
Who has build wheels using the ARC MT006 32H QR 100/135 hubs?
17. Dezember 2020
Hello, good day.
I need some help confirming some measurements for the ARC MT006 32H QR 100/135 hubs please. If you have built a wheelset with these hubs (32H) with Shimano HG driver, please let me know. The diagrams provided for the hubs are unclear to me. I have measured them manually, but I need help confirming the measurements are correct.
QR/ 100mm/ 32H Front hub:
Pitch circle left: 58mm
Pitch circle right: 45mm
Flange distance left: 21mm
Flange distance right: 36mm
Spoke hole diameter: 2.5mm (14G)
QR/ 135mm/ 32H Rear hub: (Shimano 10/11S HG driver).
Pitch circle right: 49mm
Flange distance left: 36mm
Flange distance right: 20mm
Hey MrJamie,
I haven't built a wheelset with these, but your measurements fit quite nice with the attached drawing. Confusing is, that for the rear hub they obviously show the PCD of the disk brake, not the right flange-PCD of the spoke holes. This would explain the deviation of your PCD of 49mm. Considering the drawing is done in the right scale, this could fit.
All other measurements seem to be ok.
