Put it the photo of your light & its Illumination
Are you sure to take this Batteryholder?
Once i was loading any Batteries in a similar holder.
The springs has been so very hot that the holder has been damaged.
This is not the only disadvantage of these types of battery-holders, i also use one of them (6er) for my prototype-lamp. i only drive in the city, but there i have problems with the contacts -> the leds flickers at every bigger bumb (bodenwelle). but it need some time until this phenomenon happens, an new holder will work some weeks.
i think he is charging the akkus outside of the holder in a normal charger. ?
Hallo
The springs has been so very hot that the holder has been damaged.:heul:
greetings bergnafahre
Hallo, Yes, this is the holder I use. I don't have any problem with this holder. For hold the batteries, I use a tape of velcro around the batteries.
SektSchlampe I charge the batteries outside the holder with normal charger of AA type.
Gruss - Saludos - Grettins
msxtr
yesterday i build my second "Nr.5". Both lamps work with luxeon K2 (2x S00@500mA and 2x P00@1000mA) . the last days it rained in berlin so that the street reflect all the light,so i thought my lamps were off :mad:
Only using mobdar optics isnt good at all.
I will try to make some pictures from the "nr.5's" and from the beamshots. (it would be difficult to do that without an own digi-cam)
Your are right, with wet ground the light is not seen :aufreg:
I will wait yours fotos
Gruss - Saludos - Greetings
msxtr
Ich kann kein Englisch aber was er da gebaut hat macht richtig gut Licht.
Was hat er verbaut?
Bei 15 Sekunden Belichtungszeit kein Wunder. Auf den Bildern sieht man ja sogar Sterne.
Kamera-Hersteller: KONICA MINOLTA CAMERA, Inc.
Kamera-Modell: DiMAGE G400
Aufnahmedatum: 2006:12:08 19:16:24
Blitz: nein
Brennweite: 5.6mm (KB-Format entsprechend: 34mm)
Belichtungszeit: 15.000s
Blende: f/2.8
ISO: 50
Weißabgleich: auto
Belichtungsmessung: Mittenzentriert
Blitz: nein
Blende: f/2.8
ISO: 50
Weißabgleich: auto
:eek: :eek: How you see this data?
msxtr
Blitz: nein
Blende: f/2.8
ISO: 50
Weißabgleich: auto
JA ja die Camera macht immer einiges aus da werden manche Lampen gleich doppelt so hell
Hier wie versprochen meine bilder der doppel-nr.5
(Die cam ist so schlecht das die bilder fast nix taugen)
mein cockpit
Fragen zum rad beantworte ich gern.
Das beamshot bild täuscht sehr, das ganze bild gehört dunkler, man kann aber ganz gut den lichkegel erkennen.
ich weiß nur das iso400 eingestellt ist. keine helligkeitsanhebung.
Es sieht nicht danach aus als würde ich in naher zukunft anstängie digitale beamshots machen können, ich kann mal mit einer spiegelreflex probieren ob ich vernünftige fotos hinbekomme.
Hallo!!!!!
Stevens M8, tobbi KLEIN doppelt so hell more than twice as bright?? I think that beamshot isn't twice light that reality, anything else?, yes, but twice or more, not.
My camara of fotos don't permit time control of exposition manual.
J-CooP Thank you for this info, I did not know.
SektSchlampe wow!!! very nice lamps!!! but, where put the cyclecomputer on your handle bar??
Your camera is an analog camera??
Where bought You the handlebar support for the lamps??
msxtr
Hello, sorry i forgot to write in english.
my cam is a cheap digicam (dimage X50 konica minolta)
sorry i dont understand it :confused:
i will make some better pictures from my cockpit and some newer ones from my lamps and post the link to my pdf-file. (should be done in one and a half hour)
3 x Osram IRC @ 12V Bleiakku
Is´n bissle dunkel geworden, aber naja...
Soll nur als Vergleich dienen falls es Jemanden interessiert.
Ist eine Joerky-Lampe bei der ich die leuchtmittel immer getauscht habe.
edit: Boar der thread ist ja ätzend. Wieder nur Gelaber...
20W - 10° / 20W - 24° / 35W - 38°
This is the cateyeholder H-24/H-27 and i bought it in berlin at "zweirad-stadler". i couldn't remeber how much i payed, under 5€.
The PCB is already isolated and the K2 is also isolated.
(i cut it out)
But this PCB has a disadvantage, if you try to solder for the third or fourth time the conducting path gets of the ground, so that this PCB is useles.
at led-tech.de you can get such a cooling-PCB.
Tino
(i cut it out)
Tino
That luck have you, in Germany have very, Big stores of bicycles, but in Spain, no :heul: :heul: I see www.zweirad-stadler.com but, on line don't sell cateyeholders.
You PCB is not home made?? it seems it
Gruss - Saludos
msxtr
I dont really see the reason why to use this cutouts of the 3-emitter board (except for burning down money). ??
That way there is just another unnecessary border for heat management (which is important, especially with heaters like the K2).
:confused:
Why not mount the emitter directly to the sink, especially if the K2 is electrically isolated (which I would not bet on).
bevor wer fragt: Wärmeleitpaste, Emitter andrücken und einrichten, mit Epoxy ankleben, dabei gleich ein wenig Epoxy unter die Kontakte fließen lassen. Nachm Aushärten ganz normal anlöten
Da hab ich wohl nicht überlegt bevor ich meine Lampen gebaut habe ;) . Bei meiner Version mit 28mm Kupferendkappen sind die 1,5mm Dicke der Kühlplatine sogar notwendig um die led im richtigen Abstand zu montieren. Ich habe diese Methode dann einfach bei den späteren Modellen fortgeführt. Mir gings wahrscheinlich darum die Kontakte vor dem Abbrechen zu schützen.
Ich hab mich heut mal mit digicam bewaffnet und bin raus auf die straße und hab ein bild gemacht:
Ich hatte mir katzenaugen hingelegt um bestimmte entfernungen zu markieren (stehen in lila daneben) hab per software die katzenaugen nochmal markiert.
Von der helligkeit des himmel könnte es in etwa so hinkommen, vielleicht ein mü dunkler. in berlin wirds leider net dunkler und bock zum see zu fahren hatte ich heut auch net mehr, wenn ich ne bessere digicam habe dann mach ich bilder gelände und im stadtverkehr.
Als lampen kamen 4K2's zum einsatz (2mal S00@500mA und 2xP00@1000mA)
alle mit mobdar. die S00 sind für den entfernteren lichkegel zuständig. sie leuchten um einiges gelber als P00. wenn ich die P00 auf den punkt der S00 ausrichte, dann ist da nicht so schön ausgeleuchtet. mal gucken was bei rauskommt, wenn ich die S00 bei 1000mA fahre.
Zur digicam konica minolta dimage x50:
Iso 400
blitz aus
keine überbelichtung
belichtungszeit unbekannt
soviel erstmal von meinen lampen.
Grüße Tino
