Firmware eTrex 20/30 version 3.00
13. Dezember 2004
4.532
ab sofort zu haben...
Change History
Changes made from version 2.90 to 3.00:
  • Fixed several issues with sorting photos in the photo viewer application.
  • Fixed issue with prompted routing.
  • Fixed issue with saving a track's 'show on map' status across a power cycle.
  • Fixed issue with displaying tracks on the map after performing an area calculation.
  • Fixed issue with BirdsEye imagery's status not being saved to each profile.
  • Fixed issue with tempe sensor's status not being saved to each profile (eTrex 30 devices).
  • Fixed potential shutdown when viewing certain tracks or routes in German or Russian.
  • Fixed possible issue with reviewing a track's information.
  • Fixed possible issue with searching for an address in cities with extremely long names.
Changes made from version 2.80 to 2.90:
  • Added Adventure support with latest version of BaseCamp. See TrailTech (http://garmin.blogs.com/softwareupdates/2012/08/garmin-adventures.html) for more information.
  • Added support for new tempe sensor on eTrex 30 devices. See TrailTech (http://garmin.blogs.com/softwareupdates/2012/08/tempe-sensor.html) for more information.
  • Improved accuracy of compass calibration on eTrex 30 devices. A new manual compass calibration is required (Setup > Heading > Calibrate Compass).
  • Improved map drawing at low zoom levels.
  • Improved load times for geocache descriptions.
  • Improved Ascent and Descent calculations.
  • Fixed issue with preserving routes imported from BaseCamp (identical maps required).
  • Fixed issue with picture rotation when using the photo viewer on eTrex 30 devices.
  • Fixed possible error message when disconnecting the device from a computer.
  • Fixed possible issue with viewing geocache descriptions in night mode.
Changes made from version 2.70 to 2.80:
  • Added ability to sort waypoints alphabetically
  • Improved GPS response at low speeds
  • Improved ability to clear unit settings on power up: now only requires menu key and enter key to be held when powering the unit on
  • Improved size of roads drawn on map in 'automotive mode' orientation
  • Improved elevation data stored in track logs (etrex 30)
  • Fixed issue that was causing some devices to display a 'memory full' message followed by bad device behavior
  • Fixed issue with distance to destination data field
  • Fixed occasional overlapping of data fields in the elevation application
  • Fixed issue where waypoints and geocaches could be lost
Changes made from version 2.60 to 2.70:
  • Fixed issue that could occur when restoring map zoom level defaults
  • Fixed issue with track distance data field in stopwatch application
Changes made from version 2.50 to 2.60:
Changes made from version 2.40 to 2.50:
  • Fixed issue where project waypoint feature would only work once per power cycle.
Changes made from version 2.30 to 2.40:
  • Improvements to the geocaching experience. See TrailTech (http://garmin.blogs.com/softwareupdates/2011/09/improved-geocaching.html) for more information.
  • Improved behavior on startup when importing large numbers of waypoints, tracks, routes, or geocaches
  • Fixed issue where the progress bar would not display any progress when importing waypoints, tracks, routes, and geocaches
  • Fixed issue with very long geocache descriptions
  • Fixed shutdown when reviewing certain geocache descriptions
  • Fixed issue where some auto-archived tracks would be named in English regardless of user language
  • Fixed issue with track log recording while using the stopwatch
  • Fixed potential shutdown while scrolling through Garmin Connect photos
  • Fixed minor graphical issue with the backlight slider on the status page
  • Modified default map trails to appear as dashed red lines
Changes made from version 2.20 to 2.30:
  • Improved support for Russian cartography.
Changes made from version 2.10 to 2.20:
