geeks,nerds,enthusiasts und racers gesucht!
klaus nielsen
www.pronghornracing.com
6. Januar 2009
Dänemark
Hallo Alle!
I would like to get in contact with a number of true MTB Geeks, Nerds, Enthusiast in germany like: Pro and no pro racers, sales guys, industry people or people who are living for biking, that would be interested in helping to promote and build a new high end MTB brand.
For the right people we can offer great deals. It is not og big importance to write or speak english perfect.
Wir kann uns auch ein bischen in deutsch unterhalten...
For more info and contact, check out our sponsorship program at:
That might be true, you can allways discuss design. This frame was not designed to be pretty, but designed to be efficient. The function was always in first priority when this bike was designed. You should try to testride it, you would be surprised how it works. You can also check out the test i bikesportnews, the january issue.
I like the position of the rear shock, it`s unique and far removed from mud, dirt an so forth, furthermore it makes lockout lever on the shock easy acessible!
unfortunatly I culd not see eyelets for a second Bottle cage on the saddle tube - even if only an sidecage might be practikal, never the less a second one would be important for long distance tracs.
opticaly the cables inside the top tube are nice but in my opinion reqiure more work while changing shift cables.
the carbon frame is a little to extravagantly bent for my liking ( little bit like the "hydoforming -desing" - used on some spezzialiced frames - brr)
I am curius if a bent top tube witch also has to support the rear shock would not have to be rather massive an heavy - what is the frame wight of the Alu and the Carbon version?
Is there an geomety table with the length and arches in the different sizes, i could notfind it on the hp?
I would be quite intrerested in a test ride, is there an possibity near Frankfurt m. or at Willingen bike festival or the eurobike?
best regards
PS sorry for the spelling - I am not used to writing in English
I will be racing most of the bundesliga this summer, at most of the races there will be 1-2 demodays where new customers can testride the bikes. The demodays will later be announced in a calender on the pronghorn homepage.
Well, there might be pieces of mud falling off from the rider onto the damper. This won't happen with the damper inside the front triangle.
The PR6-SW Carbon-XC Race frame looks great! I like the unconventional design, and the weight, of course, is pretty good.
However, is there enough clearance for a 0,75 litre-bottle within the 16" front triangle?
best
corfrimor
best
corfrimor
Hallo Corfrimor!
Es freut mir dass unser rahmen dir gefällt. Ich glaube leider dass es knapp wird mit ein 750ml flasche in ein 16". Vielleicht würde es funktionieren mit ein flaschenhalter wo man die flasche von die seite reinschiebt?
Ich untersuchen es, und schreibt wieder.
Bis dann, Klaus Nielsen
