how fit fox 36 talas to spice lapierre 516 frame?
13. September 2017
Hello ..can you tell if i can fit fox 36 talas 160mm with 1,5 straight tube in my frame lapierre spicy 516.i take as a gift from somebody and i want to make it run .i bought i fabergabel fox 36 talas but it has straight tube 1,5 zoll but in frame that it has, was smoller 1 1/8 .i take out the old steuersatz from frame
And mezoure the inner dimention diametre and it is 44mm .please can you help me to find the way to fix it?.i am looking for 1,5zoll steuersatz for my gabel
kmfDuF
https://ibb.co/kmfDuF
https://ibb.co/hfioTa
https://ibb.co/dbtBgv
https://ibb.co/c6ocMv
https://ibb.co/hWdNoa
https://ibb.co/cF3Bgv
https://ibb.co/bOa2oa
You´ll need a EC44/38.1 top and EC44/40 bottom headset to get this together.
I do not know if this headtube will have a sufficient depth to accomodate this type of headset.:ka:
ok ...now how find cheap way to buy them...i see the cost is about 50~70 euro...it is to much for me....if can help me find used....i don't care.at this moment the first i want to do is to find all parts i need ,to start montaz ,thanks ...
I dont think, you will find one fitting there.
The bottom cup EC44/40 is not the problem.
This one is really common, used for tapered forks.
The upper cup is the problem. EC44/38.1 is not common.
You will not find such a cup from every brand.
The only ones i know are from Nukeproof (discontinued) or Reset.
You could buy a cheap one for the bottom cup,
but you have to buy the reset upper cup.
Who will assemble the headset?
by myself ...with the help... of youtube...i am not used it for race, just for fun...
Can i use the EC 44/40 in both sides? Will be there any problem?Might i put something like a ring of steel 1,5mm to the upper Headset ?So it tights up so it can fit. Will there be any problem?
Any Problems? Lets face the truth. Your bike technic knowledge is very low, the chance to sell the Fox is very very low. There is no cheap way to fit the fork.
The headset of reset would be optimal. If it is too expensive for you, you have to look for a normal EC headset and have it machined off.
If you build a bracket for the headset, you can even saw it off with a circular saw. You just need a hardened saw blade. I've done it before and it still works fine. I simply screwed the headset onto a wooden block and sawed off a few millimeters. It just has to be really tight on the log.
