C
CarstenB
Guest
wwwfund, von 1993, Rahmen Gabel, Vorbau, Steuersatz, Sattelstuetze fuer ein gebot ab 110 englische pfund, finde ich ganz ok. auf jeden fall ein schoenes rad und schoene bilder
http://gallery23409.fotopic.net/show_collection.php?id=59418
[email protected] ist der verkaeufer.
kenne den verkaeufer nicht und weiss auch nicht ob er nach d verschickt. ist aber an sich kein problem und kostet ca. 30pfund.
gruss, Carsten
I am selling the following as one lot and one lot only. I won't split it.
1993 Kona Cinder Cone frame (20")
1993 Kona P2 triple-butted rigid fork (1 1/8" threaded)
1993 Kona Impact threaded headset (1 1/8")
1993 Kona Velocity Cro-mo quill stem (0 deg rise, 150mm, twin-bolt front)
1993 Kona O-Beam seatpost (26.4 x 330mm)
1993 Kona Seat Collar (allen bolt fixing)
The overall condition is just outstanding considering it's a 10 year old bike.
Items to note:
The Tange cro-mo frame is 100% arrow straight and in original colours with original stickers - there are no aftermarket stickers on it. There are a couple of paint chips as you would expect, but are barely noticeable - there are a couple on the top tube, one on the downtube, some chainsuck marks and a little chipping around the rear dropouts; all are cosmetic only and you can barely see them once the bike's built up. I have fitted adhesive clear plastic on the cable rubbing points and right-hand chainstay (the original chainstay protector is underneath the clear plastic). Everything works perfectly - the stem stays tight, the bearings in the headset are in good condition and it's a great ride.
All the little bolts are purple, in case you hadn't noticed. If purple isn't your thing, I can replace all the bolts with silver ones. Fully built, rigid and with gears, it was about 24lbs as in the pics. Turn it into a SS and see the weight drop.
Front mech size is 28.6 band, bottom pull.
For more information on the frame sizing and geometry, have a look at the '93 catalogue:
http://www.konaretro.com/showarticle.php?path=articles/catalogues/&id=1993
Words cannot describe how much this bike has been loved and how much it shall be missed. This is your chance to own a piece of history; a fine example of a classic steel Kona.
I am based in London, but I will professionally pack and deliver at however much it costs (buyer pays postage). Reckon on about £12 at least. Or you could collect it. Or I can deliver if you're also in London. Wanna come see it before you buy? No problem - just drop me an email.
Lastly, I want an offer over £110 for it, not including postage.
gruss, Carsten
Items to note:
