zepreeme Registriert 15. Oktober 2023 Reaktionspunkte 148 Freitag um 17:50 #1 Hello, I am looking for an early Litespeed seatpost in 26.8mm. Who has one to spare? Please help me finish my Litespeed build... Thanks Martin
DrmZ Registriert 25. Mai 2019 Reaktionspunkte 12.236 Ort Ostseeküste Gestern um 09:07 #2 Is that a shim in your frame? I have a 27.2mm litespeed post.
zepreeme Registriert 15. Oktober 2023 Reaktionspunkte 148 Gestern um 10:54 #3 DrmZ schrieb: Is that a shim in your frame? I have a 27.2mm litespeed post. Zum Vergrößern anklicken.... Yeah it is an aluminum shim that Litespeed bonded in (before cutting the slot). I believe they put these in to prevent galling. Cheers Martin
DrmZ Registriert 25. Mai 2019 Reaktionspunkte 12.236 Ort Ostseeküste Gestern um 11:26 #4 Ah okay. I thought maybe you can switch it for a 27,2mm shim. But in that case my seatpost will not help you.
zepreeme Registriert 15. Oktober 2023 Reaktionspunkte 148 Gestern um 23:01 #5 DrmZ schrieb: Ah okay. I thought maybe you can switch it for a 27,2mm shim. But in that case my seatpost will not help you. Zum Vergrößern anklicken.... Yes, that would’ve been a great solution with a shim. Thanks a lot for your offer anyway!
