problem Tune kong 12 mm naben
6. August 2008
Hello,
Can somebody tell me how I can take out the axle from a 12 mm tune kong hub. I already found it for a normal one but does anybody know how to do it with a 12 mm hub.
already thanx for the help
hi,
tune uses normally verry thight tollerances, which is a benefit and a plague.
If the axle is nearly blocked in the hub take a hammer and try to get it out but please do not take a nine pound hammer!!! Do it with soft hits with a plastic hammer.
Do you use a Aluminium or steel axle?
Best regards
spokie
