Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
This is probably a simple question for most of you, but I'm a bit confused. Is a Shimano Ultegra derailleur of the reverse spring type or top normal type?
hi
didn't quite understand that one, what is "reversed spring typw" supposed to mean? are you talking about the infamous solution shimano refers to as "inverse" shifting, i.e. the rear derailleur? if so: no, ultegra is standard. if you fit it without the operating cable it will move outwards to the smallest/fastest gear-cog of the cassette.
Shifting an Ultegra-derailleur is always "standard" - just like any Shimano group. AFAIK the inverse shifting has only been available as option for XTR untill Shimano released its 2003 group where the inverse logic is standard due to the dual controler.
what does "top normal type mean"? are you talking about a front derailleur then? a top-pull one where the operating cable comes from the top, that is direction of the saddle? or is the rear derailleur you're interested in?
Sorry for the confusion. No, it's the rear derailleur
RD-XCR650-SGX
Pulley cage size Mega long cage
Compatible Speed 27S
Dual compatible shifter design
Swing arm mechanism Yes
Spring system Top normal type
Twin-pull cable routing
Max. rear sprocket 34T
Min. rear sprocket 11T
Total capacity 47T
Light action spring
Guide pulley 13T
Tension pulley 15T
