CLEANING DO's and DON'TS
Do: Wipe all excess water, mud, and sand from the upper tubes, lower tubes, and crown area with a clean rag or bristle brush (Park makes a great one!).
Do: Wet a rag, or spray your fork with isopropyl alcohol or degreaser. Wipe the crown, top caps, upper tubes, dust seals, and lower legs clean.
Do: Apply fork oil, RedRum, or Teflon-based lubrication to the upper tube area nearest to the dust seals. Cycle the fork a few times to circulate the lubricant. You can even gently pinch the dust seal, nearest to the upper tube, and add some lubrication (mentioned above) to the inside of the dust seal. This will lubricate the foam ring. Wipe away any excess oil from the upper tubes and dust seals.
Don't: Stop by the local car wash and spray your bike with a power sprayer. This can force water into the dust seals and contaminate your seals, foam rings, bushings, oil, and rebound damper with water, dirt, and sand.
Don't: Use a solvent (think WD40) to clean or lubricate your RockShox suspension.
Use suspension or Teflon-based lubricant. Solvent will damage o-rings, seals, and bushings.
KEINE REDE VON BRUNOX!
Quelle: http://www.sram.com/de/service/rockshox/tuning_tips.php#DosAndDonts
