Danke für eure Antworten.
Aber schon seltsam dass es das Blackbox Element schon seit 2007 gibt aber niemand weiss ob es wirklich viel bringt
Nun noch ein abschliessende Frage.
Wie schauts mit der Haltbarkeit aus?
Ist die Blackbox theoretisch anfälliger?
Folgendes theoretisches Statement zur Blackbox habe ich noch im Netz gefunden:
Here's why it's better. In short, the damping in your forks works by moving oil through a piston. In an orifice damper, there are simply small holes in the piston for the oil to flow through. Since the holes aren't that big relative to the size of the piston, oil can only flow through them so quickly. Thus the motion of the fork is damped. A shimmed damper works on the same principle, but goes about it in a little more sophisticated way. Instead of just having some small holes in the piston, the holes are larger, but are covered by a stack of thin steel discs (shims). When the piston tries to move through the oil, the shims flex and partially uncover the holes, allowing some oil to flow through. The faster you try to push the piston through the oil, the more the shims will flex, and the more oil will flow through.
This is better because it allows the damper to better handle a range of shaft speeds. Think of it like a door that you're trying to control traffic through. You don't want people to run through, but you don't want them waiting to be able to go through either. If the door is of fixed size, you'll run into one of two problems. If the door is big, if not so many people want to go through, they'll have room to run, and will be inclined to do so. If the door is smaller, and a lot of people want to get through, a traffic jam will ensue. This is like an orifice damper. It'll work fine under some circumstances, but will have a hard time being just right for big and small impacts. If you have a door that you can control the size of, you can set it so that there isn't enough room for people to run, but there's enough room for them to get through quickly. This is like a shimmed damper. In the case of rebound, this lets it return quickly from big hits, and not pack down, while not feeling bouncy and underdamped over small bumps.
As for how much better the Blackbox MoCo really is, I haven't ridden two otherwise comparable forks back to back, so I can't really say.
