Freaky-blue
::Matschbombe::
- 8. Mai 2013
- 5.162
Ab Werk war der große Volume-Spacer verbaut.
ich möchte mehr Progressivität
Was war dann deine Lösung?
What differences, if any, have you noticed between your "old" FOX Nude 5 EVOL and your upgrade to the RockShox DELUXE NUDE-C1 RLC3 version? I have a 22 RC Pro that comes with the FOX Nude 5 EVOL but the later 2023/24 version includes the RockShox NUDE 5 RL3. I have had no problems with my shock but am curious as to why they changed it (the price of the Pro model has also dropped).RockShox DELUXE NUDE-C1 wenn ichs gerade richtig in Erinnerung habe in der RLC3 Version.
None so far, since the build is currently still in progress. Main reason for the swap was the choice to have a complete RockShox setup and the RLC3 has the additional compression adjustment over the FOX shock.What differences, if any, have you noticed between your "old" FOX Nude 5 EVOL and your upgrade to the RockShox DELUXE NUDE-C1 RLC3 version?
Thanks for the update it is appreciated. I am certain other people would also be interested in your feedback so keep us posted on your build and whether you also find the slow speed compression settings useful.None so far, since the build is currently still in progress. Main reason for the swap was the choice to have a complete RockShox setup and the RLC3 has the additional compression adjustment over the FOX shock.
Da hätte ich noch einen neuen an Lager... PN bei Interesse.Bei r2-Bike gibt es nun auch die Rockshox Dämpfer von Scott Spark ab MY22
What are the differences between RLC3 and RL3?
