Technical Specifications
FRAME FSR technology, A1 Premium Aluminum TransForm Monocoque, ISCG BB tabs, asymmetrical 6mm offset rear triangle, 4-position adjustable travel/head angle DH link, 3-position spring rate progression adjust, sealed cartridge bearings, replaceable derailleur hanger, 8.1" or 6.8" travel
REAR SHOCK Manitou Swinger 4-way, SPV position-sensitive damping, externally adjustable pedal platform, progressivness and rebound. 8.75 x 2.75"
FORK Marzocchi Junior T, 170mm travel, dual crown, coil spring w/ air assist, internal rebound adjust, 20mm thru-axle, integrated stem
HEADSET Cr-Mo, 1 1/8" threadless, all alloy and steel construction, loose ball bearing with seals
STEM Marzocchi Integrated stem, 55 to 67mm adjustable, 31.8mm OS bar clamp, 0 degree rise
HANDLEBARS Specialized BigHit rise bar, 6061 butted alloy, 31.8mm clamp, 6 degree upsweep, 9 degree backsweep, 670mm
TAPE / GRIPS Specialized MTB grip, black, double density Kraton
FRONT BRAKE Hayes HFX-9 full hydraulic disc, 8" rotor
REAR BRAKE Hayes HFX-9 full hydraulic disc, 8" rotor
BRAKE LEVERS Hayes HFX-9 full hydraulic disc
FRONT DERAILLEUR
Shimano M-570 LX, E-type, bottom pull
REAR DERAILLEUR
Shimano M-750 XT, short cage, standard spring
SHIFT LEVERS
Shimano M-570 LX
CASSETTE
Shimano HG-50 LX, 9-speed, 11x34t
CHAIN
Shimano HG-73
CRANKSET Truvativ Holzfeller 7050, ISIS spline, 7050 alloy, 170mm
CHAINRINGS 32Sx22S, 4 bolt, compact 104/64mm pattern, 5mm thick 7050 alloy bash/rock guard
BOTTOM BRACKET Truvativ ISIS Gigapipe 4 bearing DH, 73mm shell, 118mm spindle, E-Type
PEDALS Alloy platform, 3mm pressed pins, 9/16" Cr-Mo axle
RIMS Sun Single Track, 26" front, 24" rear, black, eyelets
FRONT HUB Specialized Stout disc, 36 hole, cartridge bearings, 20mm alloy thru-axle
REAR HUB
Shimano M-525 disc, 36 hole, sealed loose ball bearings, alloy Q/R
SPOKES
DT Swiss, 2.0mm (14g) stainless, black, brass nipples, L258/R260mm front, L233/R231mm rear
FRONT TIRE Specialized Roller RS 26 x 2.3" medium compound, aramid bead, Cap Ply reinforced casing
REAR TIRE Specialized Roller RS 24 x 2.3" medium compound, aramid bead, Cap Ply reinforced casing
TUBES Specialized 24" (R) / 26" (F) x 2.4/2.75", schraeder valve
SADDLE Specialized BigHit, 8mm Cr-Mo rails, X-Brace
SEAT POST Alloy, black, 30.9 x 300mm for 8mm rails
SEAT BINDER Alloy collar with Q/R, 34.9mm clamp I.D., black
NOTES Chain stay/seat stay protector, derailleur protector, reflectors, owners manual
Specifications subject to change without notice.
