Specialized FSR XC Expert
19. September 2008
Stuttgart
Hallo allerseits! Ich habe mich heute entschieden das 2009er Specialized FSR XC EXpert kaufen werde. Wollte nur noch mal hören was ihr hier von dem Rad haltet bzw. wollte sichergehen, dass ich damit keinen groben Fehler begehe. Ich zahle für das aktuelle Modell deutlich weniger als die 1599,- Euro laut Liste.
Hier die Ausstattung:
RAHMEN
FSR XC M4 tubing w/ new rocker design, bolt on cable guides, 120mm travel, sealed cartridge pivot bearings, disc only, replaceable rear derailleur hanger
FEDERBEIN
Fox Triad II for Specialized, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, rebound adj., 7.5x1.75"
GABEL
Rock Shox Reba SL, Dual Air, 120mm travel, 32mm stanchions, disc only, alloy steerer, Motion Control damper, rebound adj. w/ LO, mag lower
STEUERSATZ
1-1/8" Threadless, loose ball bearings w/ seals, black steel cups
VORBAU
Specialized 3D forged adjustable rise, 31.8mm clamp, S:75mm, M:90mm, L/XL:105mm
LENKER
Specialized XC low rise, 6066 butted alloy, 640mm wide, 6 degree up, 8 degree backsweep
LENKERGRIFFE
Specialized thin lock on grip
VORDERRADBREMSE
Avid Juicy 4 RSL Hydraulic Disc Brake, alloy backed organic brake pads, tool-less reach adj., cleansweep rotor S/M:185mm rotor, L/XL:203mm rotor
HINTERRADBREMSE
Avid Juicy 4 RSL Hydraulic Disc Brake, alloy backed organic brake pads, tool-less reach adj., cleansweep rotor S/M:160mm rotor, L/XL:185mm rotor
BREMSHEBEL
Avid Juicy 4RSL Hydraulic
UMWERFER
Shimano M667 SLX, 34.9mm clamp, top swing, bottom pull
SCHALTWERK
Shimano RD-M772 Deore XT Shadow, long cage
SCHALTHEBEL
Shimano SL-M531 Deore, trigger
KASSETTE
Shimano HG-50, 9-speed, 11-34t
KETTE
KMC X9, 9-speed w/ reusable Missing Link
KURBELSATZ
Shimano FC-M532, 2pc., S: 170mm, others: 175mm
KETTENBLÄTTER
Shimano 22S x 32S x 44A
BOTTOM BRACKET
Shimano M-532, integrated outboard cartridge bearing design
PEDALEN
Shimano 505 SPD, reflectors and cleats
FELGEN
DT Swiss 445D, disc, 24mm, double wall, pin joint, eyelets, 32h
VORDERRADNABE
Specialized Hi Lo disc, CNC flange, sealed cartridge bearing, alloy QR, 32h
HINTERRADNABE
Specialized disc, sealed cartridge bearing, high/low flange w/ OS contact side, 32h
SPEICHEN
1.8mm (15g) stainless, black, alloy nipples
VORDERREIFEN
Specialized The Captain Control, 26x2.2", 60 TPI, aramid bead, dual compound, tubeless ready
HINTERREIFEN
Specialized The Captain Control, 26x2.0", 60 TPI, aramid bead, dual compound, tubeless ready
INNER TUBES
Specialized Ultralight 26x2.0", presta
SATTEL
Specialized MTB, 7mm cromo rails, 143mm
SATTELSTÜTZE
2014 butted alloy, single-bolt setback, S/M: 350, L/XL: 400mm
SATTELSTÜTZKLEMME
Alloy collar with QR, 34.9mm clamp ID
