V: Paul, McMahon, Grafton, USW..
13. Juli 2009
58
Haarlem
Versandkosten Niederlande - EU = 12,75€ inclusief track und trace oder 9,50€ ohne track und trace.
Zahlungen via Bank/IBAN oder via PayPal und Paypal kosten für die Kaufer.
Und jetzt warum es dreht: Schone Teile:
19] Caramba stuff, as new, used, working perfect. Per Piece 35€ -> 25€
28] Titanium Bar-Ends. Onza copy's. Light, new, unused, 39€ -> 30€
34] Titec bar-ends. Looking good, some scratches and user marks. 15€ -> 10€
19]
28]
34]
Sold:
2) Paul front derailleur, all 3 diameters, Silver or black, see spare parts. Pulled from above. In very good condition. 225 now 200€ Sold!
3) Flite Carbon Evolution. In perfect condition! No cracks, no scratches, couple of little marks. 85€ - Sold!
4) Panaracer Magic Dart (front) and Magic XC rear. NOS! So perfect condition. 80€ - Sold!
6] Grafton Re-Entry levers. NOS! Red in perfect condition. Rubber grips are ok, but at the end worn, as can be seen in pic 2. 250 - now Sold!
7] Ringlé Ti-Stix QR Skewerset 3DV, also called Cam-twist skewers. In perfect condition, only a bit faded. 90 - Sold!
8] Answer ATAC stem, silver, 1 inch, 120mm and 10' rise. Pritty good condition. 35 - now Sold
9] Grafton Speedcontrollers SE, NOS, never mounted, black, all hardware complete! Including brakeshoes. 225€ for the 2 sets (= 2 wheels). Sold
10] Paul Stoplights, black, as new, all hardware complete + 4 x XTR brakeshoes + 2 extra rubber rings. 190€ Sold
11] Paul Moonunits, black and purple, complete, still looking good. 20€ per piece. Sold
12] Paul Brake levers, black, as new, no scratches, in perfect condition. 99€ Sold
13] Proshift Shifters, black/green, NOS! Perfect condition! 210€
With new ATI grips Sold
14] Avid Tri-Dangel purple for 15€ Sold
15] Ringle Holy skewers, black, steel in perfect condition! Only little mark on seatpost skewer end bolt. 95€ Sold
16] Ringle Holy skewers, silver, wheel skewers are titanium and seatpost skewer is steel. Skewers in perfect condition! Only little mark on seatpost skewer. 115€ Sold
17] Avid Tri-Align (long), 1 set, black, NOS, never mounted, all hardware included, also Tri-dangle. 55€ Sold
18] Onza Chill Pills, NOS, never mounted, blue. 15€ Sold
21] Ringle skewers 3th generation, titanium, black, NOS, never used. 45€ Sold
22] Ringle Holy skewers, rare green, axles are all titanium. Skewers are in good condition! Only little marks on rear wheel skewer as can be seen in the pictures. 135€ Sold
23] Ringle Holy skewers, gold, axles are all titanium. Skewers are in perfect condition! 135€ Sold
24] Control Tech Skewers titanium, black in good condition. No marks, 49€. Sold
25] Avid Ultimate levers, black. On first picture you can see the left lever has some little marks, but for the rest in good condition. For canti's! 75€ (Sold pending payment) Another set available. NOS, for 90€ Sold
29] Tioga Psycho-K, kevlar bead, 26x1.9, Amber. Very good condition as can be seen on pictures. Per piece 40€ Sold
30] IBIS Titanium stem from 1991. Almost as new, no scratches at all, very clean stem with ti stem bolt. 1 inch, 135mm and zero rise. 95€. Sold
Going on EBAY:
1] Paul rear derailleur. Silver and silver alu pulleys. Used, some marks but still in good condition. 275 now 175€
5] MCR McMahon Steely Danz Cranks. Steel, Silver, Compact 175mm and in will mount well although the left crank has 2 mm rounded, see pictures. 200€ now 150€
20] Answer Rocker seatpost, NOS, Made in Usa, Easton 6061 Al, CNC Machined never used, 26,8mm, 350mm, silver. 49€ -> 35€
26] Answer Hyperlite, purple, uncut, some marks and scratches as can be seen on the pictures. 40€ -> 25€
27] Ringle H2O bottlecage, gold, used, marks, but working well and with the L-thing! 35€ -> 30€
31] Bontrager titanium bar. 53cm long and no marks of bar-ends. 39€ -> 30€
33] Camelback and 1,5 liter reservoir. Clean! 15€ -> 10€
36] Selle Italia Flite. Very good condition, no marks or scratches. 40€ -> 35€
35] Avocet Spenco R30 Gel sattel. Used, marks, Gel is ok, Lycra must be stick again. Rails in good condition. 30€ -> 20€
Grusse, Dirk
Das sind Long pull, sprich V Brake Hebel
Hab auch solche, die funktionieren aber auch grad noch so mit Cantis
Gruss Kay
Wie weisst du das Raze? Aha, bist du die Vorbesitzer? Dan weisst du auch wie mann das hinbekommt oder?
Bilder mit von die linker Kurbel mit ein Achse montiert wird Ich am Samtag platsen :-)
Kurbeln functionieren prima! Und wann nicht: Geld zurück! Sehr einfach!
Genau darauf hat natürlich meine Frage angespielt.
Es geht nicht um "funktionieren", für reines funktionieren gibt es viele Lösungen. Es geht um "good condition". Der 4kant ist alles andere als in gutem Zustand und das nicht im Eingangspost zu erwähnen ist schlichtweg eine üble Nummer.
Sowas nimmt in den letzten Jahren ganz massiv zu, letztlich aber (hoffentlich) ein Schuss ins eigene Knie.
Die Precision Proshift Shifters gehören nun mir.
Suche noch Paul Love Levers der alten Bauart (90er) im Idealfall rot-blau look geht aber auch rot oder blau. Sollten allerdings V-Brake tauglich sein.
Genauer such ich:
von den 90er-LoveLevers die V-Brakevariante die es nur
recht selten gibt. Man erkennt diese daran, dass der Hebelbolzen näher
am Lenker liegt und damit das Druck-Zug-Verhältnis eher auf V-Brakes
ausgelegt ist. (siehe Bild) Ideal wäre Rot-Blau , Rot oder Blau.Anhang anzeigen 251045
