- 2. August 2010
- 815
Hey!Are these rebuildable and do they have TPA? (Turbo Pad Adjustment, like the original Magura HS33 levers)
Can you replace the o-rings when the lever starts leaking? Considering these are quite old by now the seals may be worn a little.Hey!
Yes, there is'n screw like the tpa adjustment. What do you mean with rebuildable?
Yes! I think you can replace the o-ring. The levers are completelyCan you replace the o-rings when the lever starts leaking? Considering these are quite old by now the seals may be worn a little.
Sind die Hebel noch zu haben? Versand nach Östereich möglich?
