Tach auch,
Wollte mal eure Meinung über das folgende Bike wissen. Vor allem was die serienmässige Ausstattung betrifft. Vor allem was die Bremse, den Dämpfer und die Gabel betrifft.
Hier nun das Bike mit der Ausstattung:
Enduro Comp
THE FEATURES
Unparalleled all-day-ride versatility from this sweet chassis - FSR technology, TransForm Monocoque frame ORE technology down tube, butted rear triangle, sealed cartridge bearing at each pivot, adj. geometry and on the fly adjustable travel thanks to the ITch Switch. (100/130mm)
The Enduro Pro tires front and rear - Mountain Bike's "Tire of the Year".
Deal with the rough stuff with the Rock Shox Psylo XC - U-Turn external adjustable travel (80-125mm), adjustable rebound and a lightweight alloy steerer tube.
Powerful, predictable new Shimano 555 disc brakes keep speed in check.
Geometry (bike metrics)
Technical Specifications
FRAME Specialized FSR technology, A1 Premium Aluminum TransForm Monocoque frame, ORE technology down tube, full sealed cartridge bearing pivots, ITch Switch 100/130mm on the fly adjustable travel, replaceable derailleur hanger
REAR SHOCK Fox Float R, air spring and rebound adj., travel adjust ITch Switch, 7.625" x 2.0"
FORK Rock Shox Psylo XC, 80-125mm travel with U-Turn external adj. travel,, rebound adj., alloy steerer tube
HEADSET 1 1/8" Threadless, 3x sealed, black alloy cups, cartridge bearings, ultralight alloy top cap and bolt
STEM Aluminum, 4 bolt, 7 degree rise, black
HANDLEBARS Specialized Enduro Mid Rise bar, 6066 Alloy, 6 degree upsweep, 8 degree backsweep, 640mm width
TAPE / GRIPS Specialized MTB grip, black, double density Kraton
FRONT BRAKE Shimano M-555 hydraulic disc, one resin, one metallic pad, 6" rotor
REAR BRAKE Shimano M-555 hydraulic disc, one resin, one metallic pad, 6" rotor
BRAKE LEVERS Shimano M-555 hydraulic disc
FRONT DERAILLEUR Shimano M-570 LX, 34.9 clamp, bottom pull
REAR DERAILLEUR Shimano M-750 XT
SHIFT LEVERS Shimano M-510 Deore, 9 speed
CASSETTE Shimano HG-50, 11/34
CHAIN Shimano HG-73
CRANKSET Specialized Strongarm 7050, XT Spline
CHAINRINGS 44Ax32Sx22S, 7050 alloy 4mm thick outer ring, 4 bolt 104/64mm pattern, Steel chainring bolts
BOTTOM BRACKET Shimano ES-30 Octalink spline, 68mm shell width, 113mm spindle length
PEDALS Shimano 515 clipless
RIMS Mavic X223, 26", black, welded seam, eyelets
FRONT HUB Specialized Stout disc, 28 hole, sealed cartridge bearings, 9mm Skraxle
REAR HUB Shimano M-525 Disc, 32 hole, loose ball bearings, alloy Q/R
SPOKES DT Swiss 1.8mm stainless, black, alloy nipples, 261/258mm front, 258/259mm rear
FRONT TIRE Specialized Enduro Pro 2.2", Kevlar bead, 120 tpi
REAR TIRE Specialized Enduro Pro 2.2", Kevlar bead, 120 tpi
TUBES Specialized Ultralight, presta valve
SADDLE Specialized Body Geometry technology, hollow Cr-Mo rails
SEAT POST 2014 Alloy, black, 30.9 x 350/400mm
SEAT BINDER Alloy collar with Q/R, 34.9mm clamp I.D., black
NOTES Chain stay/seat stay protector, derailleur protector, seatpost water bottle mount, reflectors, owners manual
Specifications subject to change without notice.
Enduro Comp
THE FEATURES
CHAIN Shimano HG-73
