Dobre dni. Moje pytanie jest bardzo techniczne. Montujemy ramę o numerze SKU-250382 przymocowaną do ramy Bergamont Big Air 6.2. Zestaw składa się z czarnego słońca z dwoma domami, czarnych posągów i kolumny pełnej pytań: jak mogę zobaczyć dwa domy? Mówi się, że czarna korona świerków pierwotnie znajdowała się w górach, obecnie jednak można ją zobaczyć w obwodzie lwowskim. Wypiłem mleko i zobaczyłem dystanię. Pozdrowienia@Ksawier Jak mogę, lub czy mogę mówić po angielsku lub niemiecku? Autotranslate informuje mnie, że jest duży problem z suszarką do włosów Dyson... Nawet nie muszę się o to martwić.
@Ksawier Any chance we can get that in English or German? Autotranslate tells me you have trouble drying your hair with a Dyson... don't think that's what is meant here.
Good morning. I have a purely technical question, namely, I ordered a set from the distributor with the number SKU-250382 for the Bergamont big air 6.2 frame and this set includes a black sleeve with two spacers, also black, and now the question is where these two spacers should go? I understand that the black sleeve goes to the bridge and then the bearings. I looked through the frame and I don't see these spacers anywhere in my frame. Regards@Ksawier Any chance we can get that in English or German? Autotranslate tells me you have trouble drying your hair with a Dyson... don't think that's what is meant here.
Thank you again for your help and please delete the other replies. Editing works weird for me and I can't delete it. He also explains things to me strangely and I don't know why. So one frame has another, but in my case there are no spacers anywhere in the frame. Thank you again@Ksawier Any chance we can get that in English or German? Autotranslate tells me you have trouble drying your hair with a Dyson... don't think that's what is meant here.
I don't have any washers in this place as marked in the photo. There is a direct connection between the bridge and the wishbone. So I don't have to worry about washers@Ksawier Please see our post above.
Link. The top one is new, which I got from you, and the bottom one is my old one. Why is it like thatAnhang anzeigen 2133642
There is no problem with the fit, but the damper can only be installed in one direction. The problem is that one element is missing from the set. Earlier in the picture I marked which element is missing from the set. Best regardsProbably some running change during production, I would assume. Are there any issues with the fit?
Hello, I don't know what happened there that one element is missing. The distributor who arranged the set for me has already been informed about it and I am waiting for a response. I hope it will be foundSo the set was packed wrong? This would be something the dealer needs to clarify with our service team. Nothing I can do here, unfortunately.
You could reuse the exisiting axle in the meantime, until there is an replacement. To my knowledge, only difference should be the color.
