manuelschafer
retrofitting+retrotec = retrogrouch
- 5. August 2013
- 1.283
@miles2014 ?JMD sagte es wären hier die Suntour Command genutzt worden.. falls jmd die noch liegen hat
Hat jemand Maße für die Teile,
dann kann ich sowas fertigen.
MfG Ronny
Bringt mir nicht wirklich was, da noch ein paar wichtige Maße fehlen, mir fehlt nur das Maß von Mitte grosser Bohrung zu Mitte grosser Bohrungen
[QUOTE = "manuel, post: 15667051, member: 282295"] [USER = 61660] @ maxim-DD [/ USER]
Can you ask smith nicely if he'll leave you the mase? He just wants to sell the parts together with the handlebars. [/ QUOTE]
He would need a 3D scan of the part as it's a bit more complex than it looks. The edges are chamfered to make them blend into the tower better. So, for anyone wanting to use M900 Rapid Fire, the holes must be drilled out which can be easily done to the correct diameter. A 15/64" bit is just right to accept the 6mm bolt.
can you tell us please the <->mm between the bigger holes (the two main holes)
this would be very much appreciated
Will take some detailed pics later today.
Hallo Ritzel Lobster,Brauchst du eigentlich noch einen Lenker?
