Latest News (Oct 2009): New maxFlex5 hardware design with incremental improvements over maxFlex4.
MaxFlex5:
Additional dedicated ground solder pad from momentary action switch (maxflex5 improvement).
Enhanced reverse polarity protection.
Microcontroller based Constant current boost regulator.
User configuration options stored in non-volatile EEPROM.
Ships configured for 350mA current limit.
User reconfigurable current limit: 350/500/700/1000 or 1200mA at any time.
UI-uni firmware.
3 user configurable voltage trip points to set independent Medium, Low warning levels and Cutoff.
If an optional 3mm or 5mm status LED is connected, the user can configure the status LED to warn when the voltage reaches Medium (status LED lights constant) or Low (status LED flashes). Now with on-board 100 ohm series resistor.
Onboard pullup resistor on switch input to provide reliable performance of external momentary action switch when used with longer wires.
Temperature monitoring of driver board. If closely coupled with the light's body, it can be user configured to force the current output to reduce. Optional trip points of 50, 60, 70, 80, 90C or off.
UIB2: Bike optimized, Choice of 2 level (duomode) or 5 level (multimode) operating modes.
UIF: 8 level dimming, fixed lighting use optimized..
UIP: 5 level dimming, flashlight use optimized.
Non-volatile storage of brightness level.
Draws < 50uA when in 'sleep mode' (25uA typical).
User selectable voltage trip point to warn of low input voltage, useful to protect rechargeable batteries from overdischarge (Refer technical section).
>85% efficiency.
Can drive up to 24V of series connected Luxeons.
Operates from 2.5V to 20V (input voltage). Being a boost converter, input voltage must be less than output voltage.
Open circuit protected (boosts to 24V maximum).
Board is circular (0.90" diameter, 0.25" thick).
