... wer erinnert sich nicht an diese kurbeln
scheinbar auch der eine oder andere bei big s in japan
werhatserfunden
flo
Sep. 21, 2003 10:58:04 PM Intersting tidbit of info: Posted By: AngryAsian
So Shimano comes out with this "revolutionary" XTR crank/BB combo for '03... it's certainly no secret that Magic Motorcycle did this sort of thing way back in the early 90's (among others, although they were, arguably, the only ones to do it successfully). Couple of observations... not only is the basic design premise the same (outboard cartridge bearings enveloped by the large cross-section hollow crankarms), but the two designs also use the exact same size cartridge bearings (#6805) and even more shocking is the fact that the cup installation tools are nearly identical and, in a pinch, are even compatible between the two systems!!! Most of you probably won't even care, but someone out there will find that interesting... Alex, are you reading this???
werhatserfunden
flo
