Bos void einstellen
Grundsätzlich was --- schrieb.
Manual zum Void (alt & neu) sagt:
Sag:
30 - 35 %
Hydraulic settings (Basiseinstellung unabhängig vom Tune):
To start your adjustment, turn the knob clockwise until it stops (clicks = 0). Then count the clicks while turning the knob in the counterclockwise direction.
Low-speed compression: 12 clicks from the fully closed position
High-speed compression: 17 clicks from the fully closed position
Rebound: 12 clicks from the fully closed position
