HeldDerArbeit schrieb:Hi Scott!
The question about the extralite frames is: what about your weight?
If you´re about more than 80kg (sorry for the metric data) - hmm.
Trial and error could became an expensive experience.
The extralite frames are very light, nice framework and cool to ride.
A friend of mine rides the suspension and he´s enthusiastic.
So , inmy opinion - a good deal and a bike you´ll not find that often.
Hellspawn schrieb:Hi Scott
The Extralite F1 is an absolute race bike. Very tough and the suspension is comperable to the Specialized FSR. I rode it and I realy like it. It gives you a big amount of extra speed, becourse of it's weight.
(And you should write in english than use the babelfish, a lot of people here understand english, but after using babelfish all the sense of a text is gone)
Scott479 schrieb:As I'm not too heavy and plan to use the F1 for X/C only I'm looking forward to building it up into the lightweight ride expected of an "Extralite" name. Thanks for the BabelFish tip-it's easy to forget how many Europeans are multilingual. One other question, the F1 has a 31.6 seatpost tube and my FRM post is 27.2, an expander from 27.2 to 31.6 is made-can anyone suggest a reason not to use the expander? I'd like to keep the FRM post.
Thanks
Scott
Thorsten_F schrieb:@scott
this is my configuration.
You see,I use ´standard´parts. In spring I´d like to tune it, where it is possible. The final weight -I think - can be 9,5-9,0 kg.New tires, some light bolts, bar ends,...... .
I rode the bike during marathons trough the year, trough the alps last year. My bike is a sports utility for me and so it is used. No showroombike.
More fotos can I send you to your email.
The bike is neutral in the (Grenzbereich??), and also makes a lot of fun on singletrails.
The bearings last now for 2500km without service, also the rear shock.
Extralite F1 Size S Gewicht 10,0 kg new in 2004
Flaschenhalter n.n wassertäger
Felgen mavic
VR Nabe tune MIG 75 32°
HR Nabe tune MAG 215 32°
Umwerfer XT top pull 31,8
Schaltwerk XTR
Sattelstütze Extralite 31,6
Sattel Flite SLR
Bremsen Avid V-Brake SD 2.0
Bremshebel FRM
Kassette XTR 12-32 Ti 11-27dura ace
Kette Shimano HG 90
Kurbeln Race Face XT 2004 ??
Kettenblätter 22/32/44
Innenlager FSA titan
Schläuche Schwalbe
Reifen IRC Mythos fast fred
Pedale SPD 747 egg beater
Gabel Sunn SCO 80mm
Schalthebel XT
Hörnchen Onza
Griffe Storck
Steuersatz Tioga Factory SL
Vorbau Extralite 6°,120mm syntace
Lenker Syntace Duraflite schwarz
Tacho Avocet 414 Altimeter
Schnellspanner Ritchey tune
regards
ok. I Take some pictures this week.
I send them then to your email.
CAn you take pictures of your details?
I don´t think that something has changed.
And what do you still want to know?
cu
Felgen mavic
Schaltwerk XTR
Sattel Flite SLR
Bremshebel FRM
Kette Shimano HG 90
Schläuche Schwalbe
Gabel Sunn SCO 80mm
Schalthebel XT
Hörnchen Onza
Griffe Storck
regards
