Flipp - Lee Mill “Pump” Track
Xmut Zadar
Full Dist
23. Mai 2003
227
Dresden
Leeds weather forecast: Bad.
Lee Mill weather forecast: Good.
Drive to Lee Mill.
Lee Mill actual weather: Bad. Unridably bad.
Instead of trials, or the drive being an absolute waste, I tried to make some sense of the "pump track".
I've ridden this on big wheeled bikes that have bouncy parts on them, and on small wheeled bikes that don't. It's equally awful on both. This video doesn't really show how bad it is.
The corners are really tight, but then there's long straight stretches before and after them. It's not well-kempt either, so there's random rocks sticking out the berms and some bits are basically gravelled-over.
Normally the downhill-ness makes brakeless basically suicide, but fortunately the weather was bad enough that the floor slowed me down enough not to pop out the tops of the berms. Unfortunately, however, this also meant carrying enough speed simply wasn't possible so yes - there is pedalling.
Looking forward to going back when the ground is hard to see if I can keep the speed up now that I've sort of figured the flow out a bit.
Got back to Leeds and it's been bone-dry all day.
Thanks Mr & Mrs Weatherfolk.
