Liteville Horst Link Bearings Replacement Manual
4. März 2016
12
Hello All!
Greetings from Big Bear Lake, California!
I'd like to contribute towards the mystery of replacing Liteville MK11 301 bearings by providing their PDF file with instructions
Bearings:
Main pivot – 2x – 6902 LLU MAX-E 15x28x7/10, (extended inner race)
Chainstays – 4x – 68012RS (aka 618012RS)
Seatstays – same as chain stays 2x 68012RS (aka 618012RS)
Top tube needle roller – 2x – na49002RS
This is the email I recently got from them and pasting it here along with PDF file
Please see ATTACHED PDF file with Instructions!
here is the list with all manuals for the frames: https://www.liteville.com/de/77/support/bedienungsanleitungen/
Please look at the MK13 manual on page 20. There you can find all bearings with article numbers and you can order the parts directly from the Syntace online shop. (MK11-MK13 bearings were the same)
Here is a pdf to download where you can see how to press the bearings in and out. https://we.tl/t-omqQH18xw1
You dont need a blind bearing puller.
