- Dabei seit
- 4. März 2016
- Punkte Reaktionen
- 12
Good day!
Today the front bolt came loose from the rear shock on the trail. Plastic and aluminum discs were also lost but I found them on the trail.
One of the needle ball bearings was damaged and had to be replaced. Here is the picture
I used a special bearing for Fox shock absorbers from aliexpress, it works wonderfully!
https://www.aliexpress.us/item/3256802460387203.html
Now the real problem is finding the needle bearing which is marked NB1115 and is hard to find in the US.
I could only find it on this site https://www.enduroforkseals.com/pro...ty-bearings/needle-bearings/NB11X15X12.7.html and as you can see it is featured with NB 11x15x12.7 That is 11mm inner diameter, 15mm bore size and 12.7m length
