If your Duke is 100mm and with the Hydra Air spring, you can lower it back to 80 as I did, made a writeup about it on another forum a few years ago: http://huckingkitty.com/forums/viewtopic.php?f=11&t=989Habe ich als RS Duke. Schoener, aber auch schwerer. Optisch top, muss sie dennoch zum Service. Dafuer auch bloss fuffzig.........Gruesse!
Open up your air spring side, push out the air spring rod, you should see the negative spring under the air piston. There's a metal pin in the middle of the spring holder, push it out with a driver and then take off the spring+holder. To lower the fork, drill a small hole about 20mm under the original hole and assemble in reverse order. It should have around 85mm of exposed stanchions, at least my 2005 Duke SL does at 80mm.yeah it is, what do you want to explain to me? I read the UK posts.
Danke mein Radl mag nur bis ca. 1500g haben ;-)
