Rock Shox
Pike 454 pop lock 100-140mm
gibt's nicht!
entweder U-turn mit 95-140 mm
oder U-turn Air mit 110-140 mm
454
Travel 95-140mm, 140mm, 110-140mm
Travel Adjust U-Turn, All-Travel, U-Turn
Weight* 2281g (5.0 lbs)2023g (4.5 lbs)2113g (4.7 lbs)
Available Spring Tech. U-Turn, Dual Air, Air U-Turn
Spring Adjust Change Spring, Air pressure via dual Schrader Valves, Air pressure via dual Schrader Valves
Damping Motion Control
Damping Adjust External rebound, low speed compression to 'Lock' with external Floodgate
Lowers Magnesium, Maxle 360 20mm, IS disc mount
Crown Forged, hollow 6061 T-6 aluminum
Steerer Tube Aluminum 1 1/8"
Upper Tubes 32mm, 7000 series straight wall aluminum, low friction anodized with travel gradients
Standard Colors Diffusion Silver, Diffusion Black (AM)
Options Remote
Suggested Rear Shox Monarch
Upgrade Over 426: Hollow crown and aluminum steerer
Max. Recommended Rotor Size 210mm
Notes *Weight based on 265mm 1 1/8" steerer with Maxle 360
