@benjamin
ich würde dir eher zur zero version mit einstellbarem winkel raten
wiegen auch nur 206 gramm in der edelstahl-achsen-version. von aussen abschmierbar.
Fixed or float, your choice.
Dual-sided for easy, no-look engagement.
Choice of fixed or limited float that can be precisely micro-adjusted anywhere within a 0-15 degree range using inward rotation and outward rotation limit screws.
11.5 mm stack height for optimal power transfer (8.5 mm on 4-hole mounting).
Unbeatable cornering clearance: Stainless - 37 degrees; Titanium - 39 degrees.
Phenomenal light weight:
Stainless pedals per pair - 206g
Titanium pedals per pair -164g
Zero cleats per pair - 105g
Large contact area, extremely stable cleat-to-shoe connection.
Compatible with virtually all 3-hole and 4-hole shoe mountings.
Standard step-in, turn-out entry and release.
Built-in grease port for easy bearing lubrication.
Two precision cartridge and one needle bearing per pedal.
Rust-proof stainless steel and titanium spindles.
True locking mechanism - engagement security is independent of spring tension.
http://www.speedplay.com/index.cfm?fuseaction=home.zero
