Schuh? Big? Hilf mir bitte
27. April 2006
Moskau
Hello guys, sorry, my german is bad.
Help me please! A few days ago i have bought Specialized Comp shoes. I always have 44 or 45 when buy standart shoes (not for biking). So, when i have tried 45, it was fitted like my toe has absolutely no place in it. It was just as maybe it is a little bit small. No free place in the front at all. I have tried 46 and it was okay for me, the leg 'seats' okay in a boot. No luft, the boot seats perfectly. But in the front there is some place (maybe about 5mm,not more). A few guys said that there might be no place in a boot absolutely. So... now i don't know what to do... A shop manager said that this is okay... And what do you think about it?
Thank you very much.
Best wishes,
Alex
Well, it is difficult to give an advice on something only you can decide. From what you have written, you should keep the 46, since the 45 are definately are too small for you.
In all my shoes If have a little space as you described. But if you also do not feel comfortable in the 46, then you will have to find some other brand of shoes.
But as mentioned before only you can decide whether the shoes fit or not.
hey!
thank you very much for an answer. In 46 size i feel absolutely comfortable. The only reason of asking you that i wonder to know, if it is okay if i have some free space in front. And 45 is not small to me, but there is absolutely no free space in front on them, so the toe feels the boot. Isn't it bad?
Thank you!
Normally there should be a little space (few mm) between the toes and the shoe. But this depends on the situation as the size of the feet is not constant. Under load (running, biking etc.) the feet will grow a little bit.
So I think if the shoes in size 46 fit your feet tight with a bit space in front then they are o.k..
Naja da musst du hoit moi übn! I hob mir Schuhe von Shimano gekauft und de hobn ned geposst - des klingt ulkig aba i pinkle doat herein und dann steige i rein und dann possn de - und zwar wia ogegossen !
Des soitest du aa testn und wenn ois ned hilft, zähne zusammenbeissn!
thank you for answers, guys! if i put my leg to the front, i can hardly put my finger inside of shoe on the back if my leg is unfitted. If it is fitted, i can't move my leg inside absolutely, so i can't put a finger on the back. So, i have the right size? I have about 5 mm free space, maybe a liiiitle more :)
Thank you!
