Specialized Rockhopper Comp 29er abspecken
11. Oktober 2005
234
Hi zusammen.
Ich besitze das Rockhopper in der Ausstattung:
http://www.specialized.com/us/en/bc/SBCProduct.jsp?spid=52808&scid=1000&scname=Mountain
FRAME Specialized M4 fully manipulated alloy frame, fully butted, Trail 29" geometry, externally relieved HT, SS compatible forged adjustable slider dropouts, replaceable der. hanger, disc only
FORK SR Suntour SF11-XCR-DS-29-LO-SP, 1-1/8" alloy steer, mag. lower, 30mm stanchions, hyd. damping w/ lock out and custom tuned spike valve
HEADSET 1-1/8" threadless, loose ball
STEM 3D forged alloy, 7 degree rise, 31.8mm clamp
HANDLEBARS Butted alloy riserbar, 25mm rise, 8 degree back sweep, 6 degree up
GRIPS Specialized Enduro, dual compound Kraton, no flange, 131mm
FRONT BRAKE Tektro Draco Hydraulic disc brake, dual piston, 160mm rotor
REAR BRAKE Tektro Draco Hydraulic disc brake, dual piston, 160mm rotor
BRAKE LEVERS Tektro Draco hydraulic
FRONT DERAILLEUR Shimano Alivo, 34.9mm clamp, top swing, dual pull
REAR DERAILLEUR Shimano Alivio, 9sp direct mount Long cage
SHIFT LEVERS Shimano Alivo SL, rapid fire trigger
CASSETTE Shimano HG30, 9-speed, 11-34t
CHAIN KMC X9 w/ reusable Missing Link
CRANKSET Shimano FC-M430-8, Octalink spline
CHAINRINGS 44S x 32S x 22S replaceable
BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
PEDALS Alloy 1pc. body and cage, reflector kit, 9/16"
RIMS Alex RHD 29", alloy double wall, pinned w/eyelets
FRONT HUB Forged alloy, hi/low flange, double sealed, ground race, machined disc mount and flange, QR, 32h
REAR HUB Forged alloy, mid flange, double sealed, ground race, machined disc mount and flanges, cassette, QR, 36h
SPOKES 2mm (14g) stainless
FRONT TIRE The Captain Sport, 29x2.0", 60TPI, wire bead
REAR TIRE The Captain Sport, 29x2.0", 60TPI, wire bead
INNER TUBES Presta valve
SADDLE Specialized Rockhopper XC, Body Geometry, 143mm width, front and rear bumpers
SEATPOST Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
SEAT BINDER Forged alloy QR, brass washer
Rahmengröße ist L.
Meine Fischwaage sagt 14,22 kg.
Irgendwelche Vorschläge wie ich es relativ günstig leichter machen kann?
1 kg weniger wäre schon nicht schlecht...aber das wird wohl nicht so leicht
Danke im Voraus
Hallo Das ist doch kein Problem.
Gebrauchte Syntace Carbon Stütze und Lenker, minimum XT Kurbelgarnitur und Kassette,Selle Italia SLR XP Sattel und vernünftige Laufräder :cool: und es sind mehr als 1kg weg :daumen:
Mein Rad wiegt 10,6 kg mit einem 21" Rahmen
Ok, merci. Ich werd noch die Gabel tauschen wie's aussieht, das sollte auch nochmal 300-400g bringen.
Und ich denke statt XT Kurbelgarnitur gibts ne SLX, der Gewichtsunterschied ist da gering.
Laufräder bleiben erstmal, aber als Reifen kommen ein Nobby Nic und ein Rocket Ron (oder 2 Nobbi Nic), die sind etwas leichter als die Specialized Captaion Drahtreifen...und die nerven mich eh.
