Hi guys, sorry for not Speak German. I only speak spanish and english.
Please help me a little.
it's time to retire my 2010 HPC Carbon Cube with 26 "and I'm between two bikes, the Stevens Whaka Carbon Max and the YT CF Pro Race at 27.5.
The two are fully equipped, but they have some differences like:
The Stevens has electronic XTR and the other Sram x01
Stevens has Boost in front and behind, and YT just behind.
For other components, I do not see very significant differences.
What I worry about is the suspension system of one with respect to the other, because I don't have knowledge about this and I would like to know your opinion, since I do not know which is more effective (good) of the two because I do not understand this. I just know that the Stevens pedaling efficiency is better than the YT (29 ") according to the linkage page for what I read.
If you do not have to look the price, who do you choose ?
Can you help me a little bit ... to my naked eye I like more Stevens, for the subject of Di2 and weighs in 12kg, but I don't understand of geometry and types of rockers .
Thank you very much for your help.
STEVENS WHAKA CARBON MAX
EQUIPMENT
CHASSIS
Frame Carbon SL HMF
Axle: QR12x148
Cable routing: internal
Front fork Fox 34 Float Factory
Travel: 160mm
Air suspension
Tapered Steerer 1 1/8" - 1 1/2"
Axle: QR15x110
Shock absorber Fox Float X Factory
Travel: 150mm
Air suspension
Kashima coating
Length: 216mm
Shock travel: 63mm
Mounting width: 22.2x8mm/31.75x8mm
Brakes Shimano Deore XT
BR-M8000
Hydraulic disc brake
Rotor: SM-RT81
Rotor size: 203/180mm
Center-Lock
DRIVETRAIN
Crankset Race Face Next SL DM32
Teeth count: 32
Direct mount chainring / 30mm spline
BB type: Pressfit 89.5
Boost chain line
Derailleur r Shimano XTR Di2 Shadow+
RD-M9050-DGS
11-speed
Direct Mount
Total capacity: 35 T
Cassette Shimano Deore XT
CS-M8000, 11-speed
Combination: 11-13-15-17-19-21-24-28-32-37-46 T
WHEELSET
System wheelset DT Swiss XM 1501 Spline One
Tires Schwalbe Fat Albert Evolution F|R
Seatpost Kind Shock LEV-Integra
Travel: 125mm
Shiftlever Shimano XTR Di2
SW-M9050
Brakelever Shimano Deore XT
BL-M8000
Weight 12.0kg
YT JEFFSY CP PRO RACE 27,5
FRAME
JEFFSY CARBON 27,5"
REAR DERAILLEUR
SRAM X01
WHEELSET
E*THIRTEEN TRSR SL 27,5"
SHOCK
FOX FLOAT X FACTORY
SHIFTER
SRAM X01
FRONT TIRE
E*THIRTEEN TRSR 27,5"
FORK
FOX 34 FLOAT FACTORY
CASSETTE
E*THIRTEEN TRS+
REAR TIRE
E*THIRTEEN TRS+ 27,5"
TRAVEL FRONT/REAR
160MM / 160MM
CHAIN
SRAM PC1130
STEM
RENTHAL APEX 35
HEADSET
ACROS AIX-326
BRAKES
SRAM GUIDE ULTIMATE
HANDLEBAR
RENTHAL FATBAR CARBON
CRANKSET
RACE FACE NEXT SL
DISCS FRONT/REAR
SRAM CENTERLINE 200MM / 180MM
SEATPOST
ROCKSHOX REVERB STEALTH
BOTTOM BRACKET
RACE FACE BB92
GRIPS
THE SENSUS LITE
SADDLE
SDG FLY MTN
CHAIN GUIDE
E*THIRTEEN TRS+
PEDALS
WITHOUT / OHNE
FRAME SIZE
S / M / L / XL
WEIGHT
12,4 KG / 27,3 LB
EQUIPMENT
CHASSIS
Frame Carbon SL HMF
Axle: QR12x148
Travel: 160mm
Air suspension
Axle: QR15x110
Travel: 150mm
Air suspension
Kashima coating
Length: 216mm
Shock travel: 63mm
BR-M8000
Rotor: SM-RT81
Center-Lock
DRIVETRAIN
Teeth count: 32
Boost chain line
RD-M9050-DGS
11-speed
Direct Mount
CS-M8000, 11-speed
WHEELSET
Travel: 125mm
SW-M9050
BL-M8000
Weight 12.0kg
FRAME
JEFFSY CARBON 27,5"
REAR DERAILLEUR
SRAM X01
WHEELSET
SHOCK
FOX FLOAT X FACTORY
SHIFTER
SRAM X01
FRONT TIRE
FORK
CASSETTE
E*THIRTEEN TRS+
REAR TIRE
TRAVEL FRONT/REAR
160MM / 160MM
CHAIN
SRAM PC1130
STEM
RENTHAL APEX 35
HEADSET
ACROS AIX-326
BRAKES
SRAM GUIDE ULTIMATE
HANDLEBAR
CRANKSET
RACE FACE NEXT SL
DISCS FRONT/REAR
SEATPOST
BOTTOM BRACKET
RACE FACE BB92
GRIPS
THE SENSUS LITE
SADDLE
SDG FLY MTN
CHAIN GUIDE
E*THIRTEEN TRS+
PEDALS
WITHOUT / OHNE
FRAME SIZE
S / M / L / XL
WEIGHT
12,4 KG / 27,3 LB
