- 3. November 2021
- 2.517
Auf der ZFC Seite steht hierzu folgendes:Falls das SS drip mal leer ist, würde eigentlich was dagegen sprechen mit Flowerpower zwischen den Silca hotmelt anwendungen nachzuwachsen?
Q) Is it compatible to use with immersive waxing?
A) Officially no. Mspeedwax and Silca hot melt are paraffin based, this is sunflower seed wax base, so the base waxes are completely different. If you are looking for a drip lubricant to use in conjunction with immersive waxing, choose silca ss drip, UFO drip, or Tru-Tension Tungsten all weather.
*NOTE – If looking to run with Flower Power wax, you CAN add directly over an mspeedwax or silca hot melt treatment and it will work perfectly. Pre prepped wax chain options are still the easiest way to get rolling on a super low friction path vs faffing with removing factory grease yourself if you don’t wish to. It is only putting a Flower Power wax chain back into a pot of Mspeedwax / Hot melt – it is unknown if over multiple instances of this if the different wax type going into wax pot may impact adherence of msw / hot melt to chain.
