Canyon Sender 2019 - Fox 40 installation hilfe!
11. November 2014
Hallo allen!
Hoffe jemand kann mir helfen mit mein Fox 40 installation problem. Im Englisch leider weil mein Deutsch nicht so gut ist (NL). Entschuldige.
I have a 2019 Canyon Sender CF XL, which I built up myself. Now I am swapping the fork with a 2021 Fox 40. I am having trouble understanding the tolerance/size of the headset stack height of the Sender and what Fox prescribes...
  • headtube of the frame is 140mm
  • with the headset, the total headset stack height approaches 150mm
  • Fox installation manual states that the max headset stackheight is 150mm (also for the Fox 40 2019 model)
How is a Fox 40 in the Canyon 2019 installed? Is it correct that it is a very tight fit?
Would be very much appreciated if anyone could point me in the correct direction! Anyone have a 2019 XL Sender with a Fox 40?
Thanks!
Philip
