Fox Vanilla DH
PsychoCowboy
Dornen-König
22. Februar 2002
Winnenden / Stuttgart
Hi kann mir jemand schon was genaueres über den Dämpfer sagen?
Ich werd nicht ganz schlau aus dem Bild.
Das Ding an dem Schlauch ist doch nicht nur ein Außgleichsbehälter oder?
Und für was ist das Luftventil da?
So what can I tell you about? How about the new Vanilla DH? Fox's Vanilla RC was, and largely continues to be, the standard in downhill. It works well, but it's starting to show its age. Today's riders and bikes are ready for something new, which they've started to find in the new shocks by Progressive Suspension, Curnutt, Avalanche and Romic. These shocks offered more adjustments and more control - a ride for today's riders and bikes. So Fox, a company that pushed rear suspension technology forward for so many years, was suddenly behind in the technology game. The Vanilla RC2 (with high AND low speed compression adjustment) was going to be Fox's new DH shock, but it was scrapped when they decided it was time to build a new DH shock from the ground up.
So, here comes the Vanilla DH. Starting with the physical
appearance, the shock body is a bit larger, and the shaft size is
increased a lot. The piggyback has been lopped off. The Vanilla DH has a remote reservoir attached to the shock body by a braided hose - it's harder to fit the piggyback reservoir into complex suspension designs (not to mention with the larger shock), so Fox ditched it for the remote reservoir.
Internally this isn't just a larger Vanilla RC, though it still uses
shimmed piston. The compression and rebound circuits used to use the same common bleed, but they're now isolated with a check valve, which helps to prevent damping fade - a complaint the pros had with the Vanilla RC.
Fox experimented with a position-sensitive version of the RC, which used bypass ports - as the piston passed the ports, damping would increase - but pros complained about the notchy "stepped" feeling. The Vanilla DH has position sensitivity, which is adjustable, and Fox says that it's a smooth transition. The reservoir has an air pressure adjustment, which adjusts air pressure behind a floating piston. This probably controls the position sensitivity. Oil is displaced from the body as the shock compresses, and this oil flows into the reservoir. As oil fills the reservoir, it forces the floating piston to move, compressing the air in the void behind the piston. By changing the air pressure in the void behind the floating piston, you can alter how much force is necessary to move the piston. Since air is compressible, the further the piston moves, the more it resists movement. With a lot of air behind the piston, it will take more force to move the piston in the later stages of travel than it will with a little air behind the piston. More resistance to movement = more damping, so there's your adjustable position sensitivity without the notchy feel of bypass ports. Look for the Vanilla DH shock to be tested by Marla Streb and the Maxxis and Yeti teams this season. If all goes well, you will be able buy the shock in merry '03.
Fifth kostet was im UVP auch 600 oder 700 euro..
Der fift mag kja funktioniern.. aber ausgereifter wird sicher der Vanilla sein.. und der ist IMHO auch besser einzustellen.. klar braucht man die Einstellschräubchjhen am 5th eigentlich nur einmal.. aber so wie die aussehen.. sollte man wirklich beim ersten dreh die Einstellung raushaben :D
Wenn ich besser fahre als nmein Vanilla RC gibts nen Fifth oder nen Vanilla DH.. aber das wird wohl in den nexten Jahren net notwendig sein :lol:
Ausgereifter der Fox.........
Nächstes Jahr findest den 5th Elementh im B1, Giant, Intense, Orange, Santa Cruz.
Auch im WC wird er sehr viel gefahren.
Ausgereift ist der 5th Elementh sicher auch.
Bei Fox ist kann man noch gar nix sagen, da nur wenige Bikes damit unterwegs sind.
Und selbst ACC als fährt noch mit dem normalem Fox.
"Billiger" ist der 5th auch mit 600€
ich finds komisch das der 5. nicht im cc gefahren wird, dort wäre er viel sinnvoller als im DH, denn wer braucht dort schon ne blockierung, eigentlich keiner
Original geschrieben von lexle
... klar braucht man die Einstellschräubchjhen am 5th eigentlich nur einmal.. aber so wie die aussehen.. sollte man wirklich beim ersten dreh die Einstellung raushaben :D
Tja, das mit diesen filigranen Einstellschräubchen beim 5th Element Dämpfer halte ich ebenfalls für ein, nicht zu kleines, Problem.
Natürlich kann man den Dämpfer einfach gem. der Empfehlung des Rahmenherstellers einstellen, aber um den Dämpfer wirklich nahezu perfekt an seinen eigenen Fahrstil anzupassen, ist es erforderlich, die Einstellungen doch zu ändern.
Leider ist das Ende des Einstellbereiches bei diesen Einstellschräubchen nicht wirklich vorhanden, so dass ein Überdrehen dieser sich nicht immer vermeiden läßt. Ist eines der oder beide Einstellschräubchen zu weit gedreht worden, dann war's das mit dem Einstellen auch schon...
Die Garantiebedingungen von Progressive Suspension sehen für diesen Fall ausdrücklich keine Grarantie vor...
Funktional ist der 5th wirklich sehr gut, die Verarbeitung läßt meiner Meinung nach jedoch zu wünschen übrig. Vielleicht wird dieses Problem ja bei der Modellpflege beseitigt.
Da wirkt der Fox DH Dämpfer doch durchdachter. Jedoch wird es diesen vorerst ja nur in zwei Einbaulängen geben. Ich glaube 216 und 222 mm.
Walde
Jetzt mal bisserl provokation..
wieso sollte der Roy turner, der bei Rs zu der Zeit war , als sie Elastomer Judys, Indys und coupe deluxe Schrottdämpfer bauten einen haltbaren Dämpfer bauen?
:lol:
:lol:
Stimmt auch wieder, aber bei einem 800g inkl. Feder wirds wohl halten.
